Choosing an LT1 ECU for Tuning
Old Jul 30, 2017 | 06:24 PM
brightaquavette's Avatar
brightaquavette
2nd Gear
Default Choosing an LT1 ECU for Tuning
I'm planning on doing a cam, headers, and heads pretty soon on my 93, and I'm trying to decide what ECU to go with. I've been searching for the last few days for information on the different options, but it seems like there's a good amount of conflicting information out there.
Which options are the best in terms of conversion simplicity and ease of finding a tuner to work on it?
I'd prefer to go with something that can be live-tuned if possible. From the research I've done a 24x conversion seems to be the best all-around swap, is that true?
Old Jul 31, 2017 | 09:53 AM
Kevova's Avatar
Kevova
For 24x you will need LS PCM the LT1 ECM is not going to run the coil on plug ignition. The 94-96 LT1 ECMs are flash programming. There are different views on whether to tune with OBD I or OBD2.
Old Jul 31, 2017 | 10:20 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
On your 1993 LTx you can do real time tuning with a Moates Ostrich. I personally see no reason to go aftermarket ECM/PCM. The GM LTx PCM is very powerful and all you need. The 1992/93 PCM S/D can be 1, 2, or 3 BAR. And with the Ostrich you can do real time tuning !!! What more can you ask for - especially with NO rewiring ??????? OK you ask sequential vs. batch ? Good question - batch with 63's will support 600 RWHP. Want more maybe then we consider sequential ?????? greg
To Choosing an LT1 ECU for Tuning
