Grease
Old Aug 2, 2017 | 05:12 PM
C4Coupe's Avatar
C4Coupe
Default Grease
Hello everyone in Corvette C4 world! Just a quick question. I'm replacing the bushings in my headlamps ( 92 base coupe ). What is the correct grease for the headlamp gear and should I pack the bushings in grease also? Thanks!!!
Old Aug 2, 2017 | 07:02 PM
C4Coupe's Avatar
C4Coupe
Default Maybe ?
I was thinking a silicone grease/paste might be best???
Old Aug 2, 2017 | 07:07 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
You will get a lot of opinions. What you have will work just fine. It is a headlight that will open and close as/if you drive in the dark, not a wheel bearing that will have spin millions of times.
Old Aug 3, 2017 | 06:18 AM
hcbph's Avatar
hcbph
I have not redone the headlights so take this as just some thoughts.
I would think a compatible synthetic grease would be better than regular moly grease. The reason I say that is it's less likely AFAIK to thicken or get harder when it's cold out. If it's always hot when you go out and you use them on a regular basis then it may not make a difference.
Like I said, just some thoughts.
Old Aug 3, 2017 | 03:29 PM
DGXR's Avatar
DGXR
Use silicone grease, sometimes called dielectric grease. As others said, in that application the bushings need preservation more than lubrication.
To Grease
