fuel pressure regulator
Old Oct 3, 2002 | 02:31 PM
Jimbo93's Avatar
Jimbo93
Default fuel pressure regulator
is this unit in the mid america rag any good? (84-96 page 4-17)
Old Oct 3, 2002 | 02:57 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Default Re: fuel pressure regulator (Jim Holbrook)
A least for L-98 engines (85-91) the Holley adjustable fuel pressure regulator is much better quality unit and easier to adjust. For adjustment the Holley uses a knurled **** that can be turned with your fingers while the others require trying to put either a wrench or screw driver under the plenum to turn the adjustment screw. A clumsy job! I know because I have had both.
Holleys are available from Summit or Jegs at about the same price as the MAD unit.
[Modified by Wildride, 1:00 PM 10/3/2002]
Old Oct 3, 2002 | 03:01 PM
Jimbo93's Avatar
Jimbo93
Default Re: fuel pressure regulator (Wildride)
What about LT1 engines?
To fuel pressure regulator
