speedo display probs in '93
Old Oct 3, 2002 | 03:54 PM
rguy's Avatar
rguy
Default speedo display probs in '93
when I hit a bump the display disappears. Does anyone else have this problem and know how to fix it?
How do I remove the display from the dash?
Thanks.
Rob
Old Oct 3, 2002 | 04:17 PM
Goody's Avatar
Goody
Default Re: speedo display probs in '93 (rguy)
Loose connection is most likely. Do the rest of the guages work, or is it just the speedo display? Do you have a Helms manual? That can explain the removal better then I can remember it.
Old Oct 4, 2002 | 08:29 AM
rguy's Avatar
rguy
Default Re: speedo display probs in '93 (Goody)
yes, the rest of the gauges work. it's just the digital display that goes out sometimes.
thanks.
Rob
Old Oct 4, 2002 | 10:55 AM
388 SOLid RoLLeR's Avatar
388 SOLid RoLLeR
if its the connection its easy to get to the cluster, just takes patience. REmove the lower dash panel, then the luminum plate, then the 2 bolts holding the column up. Lower the column, remove the bezel and there bolts around the cluster. Remember if you have the cluster removed and need to repair it get the zr1 tach while ur at it. :)
To speedo display probs in '93
