Dizzy issues --
Well I got it and it isn't held down with screws or bolts but spring loaded clamps. It forces you to advance or retard the timing ~ 10-15 degrees because the clips do not line up with the flanges on the dizzy.
I put it on anyway and tried to advance the timing. ;(
PS- Returned the POS MSD cludge and got a refund. It so happens that I had a Duralast cap on there before and I had kept the box so I returned that for new one free.
I got it all back together and the dizzy in the approximate position it was before and with the EST disconnected the thing won't start. Now I'm at a loss and kicking myself for adjusting the timing when I should have returned the POS MSD cap when I saw the latch system and just left it alone.
1st problem: Can't see the timing mark on the motor with my timing light. So I made an educated guess where the dizzy should be and put it there. Engine runs but coughs and sputters when I gave it gas.
2nd try moving the dizzy and with the EST disconnected engine runs smoothe and I can rev it without misses. So I reconnected the EST and disconnected the battery. Started again and it runs horribly. Pops and coughs when revved.
Is it possible that my EST was at fault all along?
Thoughts
Try setting things and disconnect battery to reset everything.
After double checking firing order I found they were bass-akwards IAW the bottom of the wire cover and your suggestion.
Once sorted, it started but ran rough. Was able to see the timing light and marks and it was at 0 degrees ... ADJUSTED to 6 degrees BTDC ... and it ran as well as it did when I started which is bad. So it wasn't my dizzy cover after all. Got fire on all 8 plugs so I'm hoping for fouled plug somewhere ... next.
How they came out LF on the bottom RF on top
