Bad Bog at start up..
Old Oct 4, 2002 | 04:26 AM
Blues77's Avatar
Blues77
Default Bad Bog at start up..
At start up even if it is up to op. temp. it gets boggy, and backfires a bit, if more than 1/4 throttle is given. After driving for awhile it doesnt completely go away but at 3/4 throttle, or WOT it is still there. opti, plugs, msd wires are new. Car is stock minus t-stat, ngk plugs and wires.
EDIT: Its not always there at higher speeds and after throttle is given and it finishes burping its fine and excelerates normal, except at initial throttle.
[Modified by Blues77, 2:29 AM 10/4/2002]
Old Oct 4, 2002 | 06:01 PM
Blues77's Avatar
Blues77
Default Re: Bad Bog at start up.. (Blues77)
TTT
[Modified by Blues77, 4:01 PM 10/4/2002]
Old Oct 4, 2002 | 06:06 PM
Ericthewolf's Avatar
Ericthewolf
This on the 94 sounds like a fuel problem how is the fuel pressure??
To Bad Bog at start up..
