Hesitant shift at WOT on auto.....
Old Oct 4, 2002 | 04:35 AM
Blues77's Avatar
Blues77
Default Hesitant shift at WOT on auto.....
It revs way to high in almost all gears, especially 2-3 shift. 2nd I think it almost hits redline and hangs there for alittle, have to let off gas so 3rd catches. It shifts fine other wise when Im not WOT, driving normal.
Old Oct 4, 2002 | 05:15 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Hesitant shift at WOT on auto..... (Blues77)
My 700R/4 did the same things till I had a TransGo shift kit installed to sharpen up the shifts and the shift points changed with a B&M governor recalibration kit.
Old Oct 4, 2002 | 06:59 AM
TimV's Avatar
TimV
I don't know if yours has the same TV cable set-up as my '85, but that would be the first thing I'd check. Mine was out of adjustment a while back and acted like that.
Old Oct 4, 2002 | 09:25 AM
WEDGE's Avatar
WEDGE
Ya, check your T.V. cable for proper adjustment, if it's not right it will grenade the transmission really quick, not that I'd know about that!!!
Wedge.
Old Oct 4, 2002 | 01:28 PM
mikeg826's Avatar
mikeg826
St. Jude Donor '06
Default Re: Hesitant shift at WOT on auto..... (WEDGE)
what's the proper setting for the TV cable? :confused:
Old Oct 4, 2002 | 01:59 PM
WEDGE's Avatar
WEDGE
Default Re: Hesitant shift at WOT on auto..... (mikeg826)
Find a CHILTONS or HAYNES repair manual for your year. There is a specific way to do it on my 84 and I don't know if its the same for yours. I have a ratcheting T.V. cable adjuster on mine, does yours?
Wedge.
Old Oct 4, 2002 | 02:03 PM
65Z01's Avatar
65Z01
First depress the tang on the side of the TV cable holder and slide the cable head toward the firewall.
Then press the accelerator hard to the floor, this will set the TV cable to it's nominal position.
BTW, the TV cable controls line pressure at part throttle and so part throttle shift points. Moving the cable head toward the firewall raises and quickens shift points; moving it away from the firewall lowers and softens the shift points at part throttle. When making any adjustments away from the nominal position, go in small steps as indeed a serious misadjustment can do harm to the tranny.
Old Oct 4, 2002 | 03:19 PM
Wheelman's Avatar
Wheelman
Default Re: Hesitant shift at WOT on auto..... (65Z01)
does my 89 have a tv cable???
Old Oct 4, 2002 | 09:42 PM
Half Fast's Avatar
Half Fast
Try changing the fluid and filter first. That usually cures the WOT shift problem. I'm assuming this is on the '94.
Old Oct 4, 2002 | 10:04 PM
95AquaC4's Avatar
95AquaC4
Default Re: Hesitant shift at WOT on auto..... (Wheelman)
:yesnod:
Old Oct 4, 2002 | 10:20 PM
mikeg826's Avatar
mikeg826
St. Jude Donor '06
SO should i set the TV cable back to nominal and then adjust from there.
:confused:
To Hesitant shift at WOT on auto.....
