Identifying parts
Old Aug 17, 2017 | 01:07 AM
Will Speed's Avatar
Will Speed
Default Identifying parts
I received a box of parts with my 84 c4 that I purchased. Some of these parts could be off of an 85 parts car.
But I'm really hoping you guys can identify these parts for me, especially the bigger pieces. Mainly the 5 pieces on the right side of the photo. I understand that there is a horn, some wiring harness, coolant hose. Lol.
Old Aug 17, 2017 | 08:20 AM
s carter's Avatar
s carter
Upper Left Air Diverter Valve, Just to R. Large Vac. Hose I believe Brake booster (84), Just Below it Air Diverter Pipe Goes across the front of Motor bolt to top of water pump, 2 Aluminum Pipes Hot Water Valve & pipe Goes to heater core, Harness I can See an IAC Plug & A/C in the Mess of wires so Engine Harness (84?), Black Plastic Square Door Handel filler, Upper Radiator Hose (84),Alum. Pipe Under Rad. Hose. Heat Riser goes to Air Cleaner (84) , Horn, A/C Compressor, Last Plastic Bit Bottom R. Distributer Cover (84)
