subs in a c4
Old Oct 4, 2002 | 03:27 PM
vent69's Avatar
vent69
Default subs in a c4
i have a 94, and i have got some subs to put in the back but how do i hook it since i have not rca outputs on the back of my stock radio?and how about my remote wire what would be the easiest way to do that is there a hook up or should i put in a toggle swicth. Finally is not having rca cord going to make it real staticy if so how could i fix that
any info would be great
thanx vent
Old Oct 4, 2002 | 03:46 PM
mikes84vette's Avatar
mikes84vette
Default Re: subs in a c4 (vent69)
You may wanna post this in the Audio section for more replies. If you are gonna put subs and amps in, why not go ahead and upgrade the HU as well? :confused:
Old Oct 7, 2002 | 08:27 PM
ZELLSLIFE's Avatar
ZELLSLIFE
I used the stock head unit because i didn't want to deface the dash in my 95 i bought some speaker line to rca adaptors for one amp and ran direct line level inputs into the other the power ant remote is what i have always used I also use an FM modulator disc changer all are Alpine components And I have no alternator whine at all I think if you use a quality adaptor (it also has an input level adjust on it) and good ground wires you should be fine good Luck :yesnod:
[Modified by ZELLSLIFE, 7:28 PM 10/7/2002]
To subs in a c4
