Headlight motor gear
Old Aug 21, 2017 | 10:42 PM
ocean100props's Avatar
ocean100props
2nd Gear
Default Headlight motor gear
Hi there, does anybody know what a mechanic will charge me to replace one headlight motor gear on my c4.
Thx!!
Old Aug 22, 2017 | 07:49 AM
s carter's Avatar
s carter
Thx!!
That is a Little Hard to totally nail down to a Penny, but they will Charge about an Hour to Hour and a Half for Labor Plus Parts.
So based on $75.HR Labor, $30.00 for gear (Plastic Gear more for Bronze) and Bushings (that NOT with a Mark up)
Give take $150. to $200.
Old Aug 22, 2017 | 08:05 AM
aklim's Avatar
aklim
I'd do both at the same time. Why don't you fill out your profile so someone will have a better idea of what year of car and what your location is? For S Carter, it might be $75 but here it is over $110 and possibly up to $130 so hard to say.
Old Aug 22, 2017 | 08:31 AM
s carter's Avatar
s carter
I would not Doubt it, the $75. was what was on the wall at a Tire store I went to for a replacement Tire a year or so ago.
Old Aug 22, 2017 | 08:32 AM
hockeyhead019's Avatar
hockeyhead019
just a note, if you have the option to spend a little more coin definitely go with the bronze replacement
Old Aug 22, 2017 | 08:53 AM
aklim's Avatar
aklim
OK. I just haven't seen $75 for a long time at any mechanic shop. Tire shop might be different, IDK.
Old Aug 23, 2017 | 01:16 AM
scotth48's Avatar
scotth48
Not hard to do. Took me about two and half hours the first time I did it a few weeks ago. Think I can do it in much less time on the second one. Got my pucks/bushing from the carguy8t8 on ebay.
Video available to watch. One thing will do on my second one is to remove the fiberglass cover just like I would if I was changing the headlight. That will help keep from scratching it and I think it will help to remove the one torx screw that is hard to do.
All you need are the pucks or bushing, may not even need the gasket. The gear itself will probablybe ok. There is a Dorman part number and was available at O'Reilly's and other parts stores.from carguy kit included gaskets and grease.
Old Aug 23, 2017 | 01:18 AM
scotth48's Avatar
scotth48
Corvette Fiero Firebird Headlight Motor Repair kit Pins Bushing Pellets & Gasket
ebay carguy8t8
Old Aug 23, 2017 | 08:44 AM
bac22's Avatar
bac22
I see no reason too, the gears are generally not the problem. And as some have argued here in the past (which makes sense logically) if there was a problem with opening the headlight better to have the nylon gear strip then burn out the motor using a brass gear.
Old Aug 23, 2017 | 09:13 AM
scotth48's Avatar
scotth48
Agree!
Old Aug 23, 2017 | 09:21 AM
aklim's Avatar
aklim
Mine had hairline cracks. As to that, we have no idea what to do if they decide to obsolete the plastic gear.
As to stripping the gear, I think the worm gear is steel and the replacement is bronze. Not sure if there is a stripping issue.
To Headlight motor gear
