Rear camber strut bracket design change
I've seen your "reason why" debated I believe.
Just a thought.
If we eliminate body roll though, with big bars, suspension geometry and low COG, then we want to minimize camber change, since we won't create any with body roll, but we'd be hurting traction through suspension jounce and rebound over bumps as the tire won't stay vertical on the road.
Radial tires are interesting creatures. They actually want to corner with negative camber (tires leaning into the corners). So the idea of keeping a tire perfectly vertical in cornering is not really the goal for radial tires. That said, if you look at good action shots of any production car cornering hard, you won't find any with negative camber on the outside tires. It's a whole lot harder to make that happen than people think. If you don't believe that, here's a pic of my car with 1125lb front spring, 550lb rear spring, -3.5* static front camber, and -2.5* static rear camber:
At best, you see that the front is only just vertical and the rear still has a little positive camber. At some point you have to account for longitudinal traction in braking and acceleration, though. So there are limits to static camber settings.
To the OP's question, I think the basic answer depends on whether the two camber arms (older and newer) at the same length. The newer C4 rear geometry changed more than just the camber arm length. I believe the mounting height for the camber arm was lowered to reduce the roll center height. I don't know what introducing the newer camber arm into an old suspension actually will do. One thing about all these OE arms is that they seem to have a bad habit of moving their static camber setting (the eccentric) when a car is cornered hard. The Banski arms (or any spherical bearing setup) will eliminate that.
with all of that. I was just trying to KISS an answer to "I can't believe GM would design something like that". The pic is great, and pics like that can be great diagnostic/tuning tools. At least, for a poor guy like me.
What the tire coming up means is that the car is relatively stiff in the front roll rate (spring plus swaybar), and therefore transferring a lot of grip to the outside rear tire. That makes it launch out of corners hard, possibly at the expense of steady-state grip compared to if it had more rear roll stiffness. I will probably experiment with a bigger rear swaybar to see if moving some grip to the front will be an overall improvement. I may find that helps with the Hoosiers but not with the Rivals.
I'm curious what you'll find with the updated camber rod and mount. If the length is correct, it will probably help keep the rear grip more linear, with less jacking effect (due to lower roll center). Let us know.
Whatever the actual numbers are, the measured figure in the text above was pretty mind blowing when I first read it. The roof has a hell of a job to do!
