rear fuel line replacement?
Old Aug 28, 2017 | 03:02 PM
RR40vette's Avatar
RR40vette
Default rear fuel line replacement?
i have to replace the rear fuel line, i know the rear bumper wiil needs to come off after that will there be enough room to re run new fuel line or will the gas tank need to be dropped too? looking for some advise
Thank's
Old Aug 28, 2017 | 08:22 PM
Patsgarage's Avatar
Patsgarage
This thread has some great pics of the routing of the fuel lines.
https://www.corvetteforum.com/forums...lection-2.html
Old Aug 28, 2017 | 08:46 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I was thinking the same thing! Go to page 4 for the best pics, IMO.
The fuel line is one piece from the tank to the filter. What or how far "rear" are you needing to replace? You could probably get it all w/only the rear bumper removal.
Old Aug 28, 2017 | 08:50 PM
odxr's Avatar
odxr
Start soaking those little studs with penetrating oil like pb blaster.They break off.The main suppy hose is has a crimp instead of clamps but you can cut that off.If you think your fuel pump might be on its way out now is the time.
Old Aug 29, 2017 | 05:37 AM
RR40vette's Avatar
RR40vette
Thanks for the pictures, from the pictures I'm worried the gas tank need to be dropped too. the fuel line from the gas tank down need's to be replaced and the return. along the frame rail the line looks good shape, looks like a big job!
Old Aug 29, 2017 | 10:18 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Default subbed because i have to do this
i was considering braided line foe ease of install.
Old Aug 29, 2017 | 10:32 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The gas tank would likely need to be removed...but it's not that hard.
How were you going to mate the old line, to the new segment? I agree w/the comment above about using flexible line. That would be way easier and should work fine, if secured decently.
Old Aug 29, 2017 | 11:45 AM
VikingTrad3r
Oil Producer
i have read people saying the rubber. reaks down but....its upstream of the filter and i cant imagine quality braided line being sold today whose rubber breaks down.
Old Aug 29, 2017 | 12:03 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by VikingTrad3r
i have read people saying the rubber. reaks down but....its behind the filter and i cant imagine quality braided line being sold today whose rubber breaks down.
The connection to the stock sending unit is rubber and has lasted 20+ years.
Old Sep 2, 2017 | 07:48 PM
RR40vette's Avatar
RR40vette
have a hard time find pre-bent fuel line for the rear, anyone knows of and one sells them, of i'll have to make my own
Old Sep 2, 2017 | 08:06 PM
ex-x-fire's Avatar
ex-x-fire
Nylon fuel line is the way to go. The only issue I see is hooking it up to the barbs on the fuel pump assembly.
Old Sep 2, 2017 | 08:08 PM
Patsgarage's Avatar
Patsgarage
http://www.classictube.com/1992-96.html
You did not say what year your car is, but try this.
To rear fuel line replacement?
