Twin Turbo Location
As far as mounting them, no you cant just hang em on there. you will need special made exhuast manifolds o take the heat and to hold the turbos weight. also they are put in a Callaway so that they just fit. the drivers side turbo is mounted forward, more then the passenger side, yet still set back further them where the stock exhuast mounts to the front Y pipe. it looks to be mounted between 5 and 7 cylinders exhuast ports.
The drivers side turbo has to be twisted in such a way that it clears the oil filter. the passenger side turbo is mounted back further (about in line with cylinder 8 exhuast port) then the drivers side turbo to clear the starter. Also the starter is rocked down towards the engine to give the turbo more clearence.
Then you will need a catch can to get the oil out of the turbos by gravity. They cannot be plumbed back into the oil pan because turbo drain oil by gravity, not pressure. they are lower then the oil level of the pan so it has to go elsewhere. Callaway solved this by building a catch can in front of the oil pan behind the front cross memeber. then they used a scaveging pump to get the oil out of the catch can back into the engines oil pan. The scaveging pump was built into the stock idler arm. I dont think you will find it very easy to get this piece, or one like it, so you may want to look at the electric pumps being used in the gen 4 F-bodys that are being turbocharged.
I have been thinking of doing something like this.
http://www.twinturbovette.net/images...0motor%201.jpg
[Modified by bill mcdonald, 2:42 AM 10/5/2002]
Who makes the TT kit that appea in the pic?? Look really nice... And I want that kit!!!!
[Modified by Greenbeast, 6:54 AM 10/5/2002]
C4Dreams
[Modified by C4Dreams, 3:49 PM 10/5/2002]
[Modified by 93Polo, 6:56 PM 10/6/2002]
http://www.twinturbovette.net/Turbo%20Install.html
here are some pics of the install.
I can barely remember his forum name, but I do have his email address at work.
this is something like what I wanted to build. I cant decided if I am going to go forward with it or not.
it looks like it will be a throw away cost 100 bucks in headers, that I will have to cut and see if I can get the turbos to fit with the headers. if it works, I would have to pull it and have it built out of 321 stainless. or have the guy who built that, build me the headers. that motor with the super ram was rumored to make 850 hp.
you can check out more at http://www.grapeaperacing.com
