Rearend wiggle
Old Sep 6, 2017 | 08:09 PM
unclet1's Avatar
unclet1
Default Rearend wiggle
I was driving my '95 home yesterday and the rear seemed to want to move to the right when accelerating at lower speeds (around 45) . Also seems to move when first braking. Just want to get some ideas of what to look for after Irma passes. Thanks for any help.
Old Sep 6, 2017 | 08:45 PM
Kevova's Avatar
Kevova
Not much for details, but looseness where suspension arms attach, as well as tie rods.
Old Sep 6, 2017 | 11:49 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Check the tie rods first. They control the direction of the rear wheel, the rod ends can wear out...and it's an easy thing to check.
Old Sep 7, 2017 | 07:32 AM
ttpfi's Avatar
ttpfi
Check the rear bushings. If they have not been replaced, they will probably need new poly for the rear.
Old Sep 7, 2017 | 07:46 AM
black_89_vette's Avatar
black_89_vette
I had the same issue and it turns out my sway bar bushings were shot. I replaced them with heim joint end links.
Old Sep 7, 2017 | 07:57 AM
unclet1's Avatar
unclet1
Thanks for all the suggestions guys. Hopefully Irma won't be so bad. Not looking good right now though. I'd really like to check this out.
Old Sep 7, 2017 | 01:08 PM
ghoastrider1's Avatar
ghoastrider1
bushings, bushings, bushings. Also check the rear spring bushings. Mins started going right and when I let off of it it jerked to far to the left. My rear spring bushing were almost non existant.\
To Rearend wiggle
