Nitto NT 555G2 Tires
If you can wait for the Contis, or find them in a size for you, then do so. But I have no complaints about the Nitto so far.
The ride is good and they handle well for my street driven car here on South Shore of LINY. I cannot drive to the extremes here.
Barrier
I have 11 years on my BFG KD's, and I am about to buy the G2's, as i have ZR1 size, and my options are limited.
But you also have boxed yourself in a bit on sizes. If you get 11" wheels and 315/35/17 rear tires, they will be about 1/2" shorter than the 285/40/17s you have now. So you're going to have taller tires on the front. That's not a major issue for performance, but it will look funny. You should have put 275/40/17 on your 9.5" wheels, because they would be the same diameter as the 315s. But frankly, if you were going to buy new wheels anyway I would have recommended that you just buy a full set of 18s in 9.5" or 11" widths all around and run the Rival S. Those are still fully streetable tires (they just don't last as long on tread wear) and they would be much faster for autocross work.
I am at that point with my Vette, I am not buying anymore things to keep up with the Jones's. Its fricking fast already, way beyond my driving capability..
Mine were balanced twice, then road force balanced and still I have a vibration until they warm up. I don't have but maybe 1000/1500 miles on my set. I am going to shift the front to the back (I have the same size tire option for all 4 wheels) and see if the vibration moves, then switch one more side back to front and isolate which tire it is.
Then take it(them) back to the place I bought them from.
If you can manage buying a set of dedicated(ish) 18x11 wheels for autocross use, that's really the way to go IMO. Then you can have really top-tier competition tires for that, and a nice street tire on the wheels you already have. For street use I just run my stock 8.5/9.5 sawblades with 245/45 and 275/40 tires (I was super cheap and bought Riken Raptors for them - all four cost less than one 315 Rival S!). You can get the Forgestar CF5 or F14 for about $1440 in my size, and I'm sure you can request a 32mm offset or close to it so no spacers would be needed. One thing to consider: you might want to think about 50mm offset plus 3/4" spacers. That way if you want to sell them you have a much bigger market of C4s and maybe even C5/6s that they would fit. It's always better to have wheels with too much offset than too little, because you can always use spacers. Another option for you might be four rear (18x10.5) C5 Z06 wheels. They'd need spacers too, but they are often cheaper than new Forgestars. There are repros, too: they are cheaper but heavier. So you have some options.
But either tire is equally fast, and at this time these are the only two top choices. The Falken RT615K+ is also available in the 315/30/18 size. It's a step down in grip, but probably lasts longer. Everything else is at least one more step down from there.
I don't understand the reasoning some people give about a grippier tire being "way beyond my driving ability." The more grip a tire has, the safer it is at any given speed. And for competition, if you aren't pushing the limits of your tires then you need to drive faster. It is really that simple. If you are trying to say that a beginner should build seat time on a cheaper and long-lasting set of less grippy tires, I can generally agree with that. But tdereggi was asking about tires that would have improved autocross performance over his previous tires. I did give him a lower-cost, multi-use option of the Continentals, which are still way better for autocrossing and the rain than a Nitto G2, and aren't too expensive (just not available in the 315 size). He of course gets to choose in the end.
