After Corsa Dyno-- I need the LT4 Knock Sensor...
Old Oct 6, 2002 | 01:13 AM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
Default After Corsa Dyno-- I need the LT4 Knock Sensor...
TITLE EDIT: That should be LT4 knock MODUAL!
Today i got a chance to dyno my car once again.
Last time i my best was 268hp/308tq at the rear before the corsa.
This time i could only muster 270hp/320tq rear wheel, BUT you could definatly see in the dyno graph that something was going on at high RPM. Heck, i could even feel it. The comptuer was def taking out timing.
So, considering that this is a stock motor, and that all i changed was the Corsa, and a little consultation with SloRVette and Scorp, we decided it must be false. After all, we all know the LT1 sensor sucks. So, i guess its off to buy the LT4 modual. No biggie, only $40 or so! :yesnod: :cool:
I'm guessing i could have seen 285-290rwhp and close to 330 rwtq if it didn't pull the timing out.
btw: anyone have the number for the LT4 modual? :cheers:
[Modified by Mervz, 12:14 AM 10/6/2002]
Old Oct 6, 2002 | 02:12 AM
scorp508's Avatar
scorp508
You're definltely losing a little power, but 290 from a catback I doubt is going to happen. ;)
Old Oct 6, 2002 | 01:03 PM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Default Re: (scorp508)
:smash:
You need to look at the graphs again brotha... :jester
Its cutting out ALOT. :D
Old Oct 7, 2002 | 12:18 AM
Shriker's Avatar
Shriker
Default Re: (Mervz)
Gaining over 15 rwhp from a Corsa catback on an otherwise stock LT1 would be pretty impressive . I would guess more like 5-10+ rwhp would be in order. In a dyno test of five catbacks on aLT4 GS the best gain was only 12 rwhp worst was about 4 , I believe. Two best were the B&B and Power Effects (at wide open setting), Corsa was NOT included in this test but is more restrictive than these two and I doubt would have made MORE power.
No flames but, I think scorp508 is being realistic...... :seeya
Old Oct 8, 2002 | 12:25 AM
billyhay's Avatar
billyhay
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: After Corsa Dyno-- I need the LT4 Knock Sensor... (Mervz)
Don't know if you got it yet but here it is just in case you didn't.
16214681
Old Oct 8, 2002 | 01:29 AM
GlockLT4's Avatar
GlockLT4
Default Re: After Corsa Dyno-- I need the LT4 Knock Sensor... (billyhay)
I have a knock module for you. $25 plus shipping? I don't need it anymore now that I have an LT4 ;)
[Modified by Glock'94, 11:31 PM 10/7/2002]
To After Corsa Dyno-- I need the LT4 Knock Sensor...
