No power on 85 Corvette
Old Sep 19, 2017 | 09:15 AM
myC4L98's Avatar
myC4L98
Default No power on 85 Corvette
I went to garage to start the 85 Vette, it had been setting about a week and a half. Turned key on and nothing, no dash indicator lights no interior lights. I put the battery charger on the battery expecting it to be dead but it showed a 90% charge. Is their a fuse link or fuse for the power circuit? I looked at diagram for the fuse panel but didn't see anything for a main power circuit. Any ideas?
Old Sep 19, 2017 | 09:52 AM
Silver85's Avatar
Silver85
I would start with cleaning the battery terminal connections and chassis grounds. Get a voltage meter and start tracing where the voltage and isn't.
I don't believe there is a main fuse but there are some fusible links you will need to check as well.
Old Sep 19, 2017 | 10:53 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Get the battery load tested, it may show high voltage but is really toast.
Old Sep 20, 2017 | 09:40 AM
myC4L98's Avatar
myC4L98
Thanks for the info, took the battery off and had it checked. Battery was bad puttiing out 8.35 volts. installed new battery. Started right up.
To No power on 85 Corvette
