corvette shtting down
Old Sep 23, 2017 | 04:03 PM
aivanjp's Avatar
aivanjp
Navigator
Default corvette shtting down
my 1994 corvette is shutting down completely when the temp reaches only 180 to 190 degrees, new water pump, radiator has been removed and cleaned, it runs perfectly in the driveway but when i take it on the road it dies. left me stranded twice.
Old Sep 23, 2017 | 04:08 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Could be a lot of things, but the usual culprit is the Opti spark.
Actually we really need more information; Any codes?starts and idles ok? any symptoms prior to shut down?
Old Sep 23, 2017 | 05:10 PM
aivanjp's Avatar
aivanjp
Navigator
The car runs fine when just sitting in the driveway. I had the optispark replaced a year ago after a water hose split and water got into the distributor they replaced the water pump when they replaced the optispark.
Old Sep 23, 2017 | 05:14 PM
aivanjp's Avatar
aivanjp
Navigator
No symptoms prior to shutdown it just shuts down - pull over to the side of the road and sit there. It was restarting and cycling off and on - car would drive for a mile or so - but now it won't restart at all until the temp drops down below 150 or so.
Old Sep 23, 2017 | 05:30 PM
Drifter36's Avatar
Drifter36
I replaced my opti a few weeks ago because of similar symptoms. But my engine threw a dtc16 which is certainly related to opti failure.
Do you know what brand opti was installed?
Old Sep 23, 2017 | 05:32 PM
aivanjp's Avatar
aivanjp
Navigator
I have no idea what type of options spark is is installed. Is there anyway to check?
Old Sep 23, 2017 | 05:38 PM
Drifter36's Avatar
Drifter36
I was more curious as to which brand may have failed. It's hard to visually tell which brand was installed.. I think MSD has a red housing..
As a first step, You should have the engine checked for any diagnostic trouble codes that may have been generated.
Old Sep 23, 2017 | 05:53 PM
aivanjp's Avatar
aivanjp
Navigator
I'll try and see if it is throwing any messages
Old Sep 23, 2017 | 06:08 PM
billschroeder5842
This would not be the first time that a "newer" part failed.
Did you wash the engine recently perchance?
Old Sep 23, 2017 | 06:17 PM
aivanjp's Avatar
aivanjp
Navigator
No, I didn't wash the engine recently. I am aware that could cause problems with the opti spark. I am stumped.
Old Sep 23, 2017 | 07:25 PM
Palanon's Avatar
Palanon
May be a bit obvious but, when cleaning the radiator, did you check the cap. could be as simple as that. Don't think it would throw a code, either. Do you know how to check codes?
Old Sep 23, 2017 | 07:37 PM
NavAir's Avatar
NavAir
OP's problem relates to temperature-related shutdowns. Nothing with the cooling system would cause this. Could be Opti, but I would bet on injectors, particularly if they are originals. My '89 had this exact problem, no codes, simply would shut down when it reached operating temperature. The injectors can have internal shorts, which manifest when they get hot.
Steve
Old Sep 23, 2017 | 08:17 PM
aivanjp's Avatar
aivanjp
Navigator
I haven't changed the radiator cap but that's cheap so I'll try it. Thx.
Old Sep 23, 2017 | 08:26 PM
NavAir's Avatar
NavAir
I must be missing something...
Why would you think that anything having to do with the cooling system is at fault. Your temperatures are normal when the engine dies. And even if the car was overheating, it wouldn't kill the engine. Since there are no codes, the Opti is probably good. I say again: Check the injectors...
Steve
Old Sep 23, 2017 | 08:28 PM
aklim's Avatar
aklim
Steve
Isn't he past that issue? I thought the injectors were no longer Multec junk by then?
Old Sep 23, 2017 | 09:00 PM
NavAir's Avatar
NavAir
True, but if he has original injectors, they are 22 years old by now, and you still could have a short.
Steve
Old Sep 23, 2017 | 09:05 PM
aivanjp's Avatar
aivanjp
Navigator
If the injectors are the issue would the car just shut off or would the engine cough and fart before shutting down.? It shuts off instantly with no skips or anything.
To corvette shtting down
Old Sep 23, 2017 | 09:23 PM
NavAir's Avatar
NavAir
Can just drop dead (thats what mine did). One shorted injector will kill the entire bank (they are wired in parallel). Your engine won't run on 4 cylinders...
Next time it dies, just pull the injector wiring connectors. Measure resistance of each injector with a VOM. As I recall, 14-16 ohms is normal for stock injectors, below 10 ohms is bad, shorted will be close to 0.
Steve
Old Sep 23, 2017 | 09:42 PM
aklim's Avatar
aklim
Steve
Good point. I'd just get a reman set at this point since they are probably crudded up to some extent after this time
Old Sep 23, 2017 | 10:07 PM
aivanjp's Avatar
aivanjp
Navigator
Ok I'll try it.
