Line lock question
Old Sep 24, 2017 | 03:44 PM
BrainDrainin's Avatar
BrainDrainin
Default Line lock question
can someone tell me the size fitting I will need for the MC on the front brake when installing a line lock. I plan to swing the original front line to the "out" o the line lock. And need to know what size that line is so I can get a new one to go from MC to linelock as well as fitting to adapt to 1/8 npt
Old Sep 24, 2017 | 08:47 PM
Kevova's Avatar
Kevova
They're metric, 12 mm nut I think and 6 mm tube.
Old Sep 25, 2017 | 06:28 AM
BrainDrainin
Awesome I'll give it a shot, thank you.
Old Sep 25, 2017 | 05:55 PM
TA's Avatar
TA
I did the same thing on mine. Not sure if you can make it out in the picture.
Old Sep 25, 2017 | 07:44 PM
1966ponyguy's Avatar
1966ponyguy
Just a quick follow up question, my master cylinder has 2 outputs for the front, one on the side and one on the bottom, how did you plumb for both outlets? Mine is an 84
Old Sep 26, 2017 | 12:28 PM
BrainDrainin
that's exactly what I planned to do, would you be so kind and tell me the size hardline you bought and those two adapters? Also I see you brought the original line straight to the line lock... I thought that wouldn't work because the line lock is 1/8 npt
Old Sep 26, 2017 | 04:36 PM
TA's Avatar
TA
Sorry, I'm not sure about the sizes. I had a buddy install the line-lock 10+ years ago.
Old Sep 27, 2017 | 12:17 PM
BrainDrainin
no problem I will figure it out this weekend, your engine bay looks great 👍🏻
To Line lock question
