4+3 shift levers cannot drill (to make short shift) with cobalt bit
the rear (long) one will not drill!!!!
i even used it as an excuse to buy a new set of cobalt bits. all they do is shine the metal a bit. i punched a dimple to start.
im not taking it to a metal fab shop just for a hole. how ghe heck was one soft and other is like bullet proof steel.
i guess im just going to install the short throw levers but id like to get this hole drilled so i can report to others who would like an alternative to the out of production 4+3 levers ss levers
I have used the short throw arms on my 85 and really could never get it aligned exactly right for reverse -- even using the 1/4" alignment hole. went back to long throw, May just be me.
Sounds like one of the arms didn't get hardened. The other did.
I went ahead and installed the kit, and will attempt what dogs said.
I tried the grinding suggestion and it didn't work.
Just sitting in the car, the mod is WELL worth it and I think I can get it even better by moving the holes even closer to the middle. I'll attempt a scale model drawing.
I read that as well, but my concern there was that the oem levers are not the same size. one is longer than the other. So not sure the shift throw would be equal if two of the same shorter reverse levers were used.
drilling holes in the oem arms does work. I am templating it and will post here when i have a chance in the next month. cheers.
