84 corvette battery keeps dieing
i replaced my alternator and battery and yet my car keeps dieing on me when i drive it i have no idea what to do at this point
Zen Vet Master Level VII
When the car dies, does ALL the power in the car go off or just the engine (with the cluster, fans, radios, etc all working) shutting down.
CAn you please elaborate a bit? There are many reasons that a car will die while driving and most are not electrical related.
Even though you replaced the alternator it sounds like it is not charging. Have you checked the voltage while it is running? It should be over 13.5 volts at the alternator while running.
Well your issue is the battery, the alternator or a combo.
When you get it started go to AutoZone and (for free) they will put a gauge on the battery and that will tell you the condition of the battery and the condition of the alternator.
The fact that the engine starts immediately upon jumping means the battery is way low. Now, the battery is either shot or the alternator is not charging. Either way you'll need to know.
Where did you get the alternator and battery?
i have not i really should have but when you buy something from a store you expect it to work but at least the C4's alternator is not that much of a hassle
No, if you drive it, you skew the test. I would take the alternator to a rebuild shop and have them take it apart and test it extensively. Also, battery needs to be fully charged so they can do a load test. If you hook it up, we have no clue if the car is draining the battery or whatever. Also, I would, while you are screwing with the rebuild shop, have them take the starter for a test and disassembly
You need to put a multi-meter on the battery while it is running to see if the battery is charging.
Sounds like the battery is not charging.
Either the battery or alternator could be bad. New things do fail.
That was the battery issue. Unfourtantly gauges don't have any numbers that are visible and car dies out but it is still able to start back up atleast going for a new fuel pump and distributor tommorow.
Btw sorry about the tension last night. I was in a awful mood and received unfortunate news.
