Oil change light
Old Sep 28, 2017 | 09:31 AM
Whaleman's Avatar
Whaleman
Default Oil change light
I know how to reset the oil change light if it is on. If I do an oil change before the light is on and go through the reset procedure will it reset it just like if it was on? Thanks,Dan
Old Sep 28, 2017 | 09:36 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes.
Old Sep 28, 2017 | 09:39 AM
WVZR-1's Avatar
WVZR-1
I believe that every year FSM will instruct you to RESET regardless of if the light was lit or NOT.
Most years it's mentioned in the OB section. You didn't mention "year" so I can't give you a page. I assumed you maybe have the FSM. I believe an Owners Manual might mention it also.
Old Sep 28, 2017 | 10:44 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Not only that, but it's right in your owners manual, in the glove box.
Old Sep 28, 2017 | 10:53 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
You could reset that light every day if you wanted too, and it would never come on.
As mentioned, no need to wait for it to come on.
You do want to make sure you reset it after every oil change.
All the monitor does is calculate (based on built in algorithms), when to turn the light on again.
The monitor has no way to actually do any oil testing.
So, every time you reset the light it starts the countdown again.
To Oil change light
