Speedo Flicker
Old Oct 7, 2002 | 12:17 AM
c4md's Avatar
c4md
Default Speedo Flicker
My speedometer keeps getting bright then dim. Where should I start to troubleshoot it? :confused:
Old Oct 7, 2002 | 01:14 AM
qwerty111's Avatar
qwerty111
Default Re: Speedo Flicker (c4md)
Not too much to go on here.......
Given the title statement without any more info, I would first rule out any electrical surge from the alternator which could brighten the panel then dim when the power returns to normal.
If the bright/dim condition is aggravared by bumps or jarring, look for a ground fault in the cluster housing. The 90-93 and susceptible to this.
Next, list the conditions under which the problem occurs.
Old Oct 7, 2002 | 01:28 AM
hngacurv's Avatar
hngacurv
You might have a bad photo sensor. It automatically dims the dash at night. Check out this site for additional help http://www.batee.com/corvette/dcrg/repair.htm
[Modified by castivers, 5:28 AM 10/7/2002]
To Speedo Flicker
