Brake Conversion
Old Oct 7, 2002 | 01:05 AM
black86ycar's Avatar
black86ycar
Default Brake Conversion
Where is the best place to buy a 13 inch front brake upgrade kit for an 86?
Old Oct 7, 2002 | 02:15 AM
zelement's Avatar
zelement
Default Re: Brake Conversion (black86ycar)
I bought mine directly through Baer.
http://www.baer.com
Old Oct 7, 2002 | 09:09 AM
black86ycar
Default Re: Brake Conversion (zelement)
Thanks - thats a nice harem you got there!
Old Oct 7, 2002 | 09:11 AM
vader86's Avatar
vader86
Id buy the C5 Brake package from VetteBrakes or from Jeff Kopp at Superior Chevrolet. Somebody will give you his number.
Old Oct 8, 2002 | 04:02 AM
GRX's Avatar
GRX
Do you have 17in wheels? They are a prerequisite. I got my kit (Grand Sport) from Doug Rippie Motorsports.
Old Oct 8, 2002 | 08:20 AM
black86ycar
Default Re: Brake Conversion (GRX)
Not yet. Does the DRM kit use the 88-96 wheels backspacing or an aftermarket 17 inch backspacing made for 84-87?
Old Oct 8, 2002 | 08:29 AM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
I also bought my Grand Sport Brake conversion from Jeff Kopp at Superior Chevrolet. I had to get the brackets to hold the new calipers from DRM. It was pretty much a simple bolt on, no real problems. If I had to do it all over again I'd get the Z06 brake package............but these blow away my old '86 single piston calipers.
Old Oct 8, 2002 | 08:43 AM
Bill Reid's Avatar
Bill Reid
Electro Dynamics for adaptors :yesnod:
Jeff Kopp for C5 caliper brackets, Z06 calipers, and pads. I recommend the 02 Z06 pads.
And then... give us a call on C5 front Eradispeeds:D... otherwise Jeff can also hook you up on some factory rotors :)
Here's what my front brakes look like:
Stopping power is like NIGHT AND DAY!!! No Joke!
:cheers:
(edit) oh ya... 17" rims are indeed a prerequisite :( ... and not all factory 17" rims will work with this C5 setup. I know for sure that AFS rims will work:) If you decide to go with a factory 13" setup I believe the factory 86 rims will work BUT they MUST have been made by Enkei. Hope this helps :)
[Modified by billreid1@***.net, 5:47 AM 10/8/2002]
Old Oct 8, 2002 | 08:53 AM
1SLO POK's Avatar
1SLO POK
Default Re: Brake Conversion (billreid1@***.net)
I have an 85. and I have brakes off a 93 (rotors and calipers) what do I need to make this work for my 85. It looks like I just need the bracket the caliper bolts to. If so where may I get 1, or what else may I neeed? I do have 17 factory wheels with adapters.
[Modified by 1SLO POK, 4:54 AM 10/8/2002]
Old Oct 8, 2002 | 09:33 AM
Goody's Avatar
Goody
Default Re: Brake Conversion (1SLO POK)
Are the new brakes the 13" size? Stock was 12" unless the J55 was ordered. Call Jeff Kopp at Superior Chevy at 1-800-728-8267 and let him know you are a forum member for a great deal on the brackets or other parts.
Old Oct 8, 2002 | 09:38 AM
1SLO POK's Avatar
1SLO POK
Default Re: Brake Conversion (Goody)
Goody, Vader,
Thanks for info, I'll give him a call after i go see exactly what size I have. :cheers:
[Modified by 1SLO POK, 5:41 AM 10/8/2002]
Old Oct 8, 2002 | 09:39 AM
vader86's Avatar
vader86
Measure the rotor size, and then call Jeff, he'll find what you need.
Old Oct 8, 2002 | 10:09 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Brake Conversion (vader86)
Go with Jeff. Price you can't beat him. For looks, go with Baer. They are the same caliper but look great from Baer. If you upgrade the wheels, you can get the C5/Z06 brakes. I did this first on my car then did the brakes. Its the best bang for the buck brakes wise and they look great.
To Brake Conversion
