ac fan switch
Old Oct 3, 2017 | 10:54 PM
weekndz's Avatar
weekndz
1st Gear
Default ac fan switch
my ac fan switch does not change fan speed. don't even have high speed. Changed resistor piece. What to check next?
Old Oct 3, 2017 | 11:31 PM
xrav22's Avatar
xrav22
I cant say what year you have but if you have no fan and changed the resistor, you may have a failed blower fan. If the resistor fails it usually defaults to high.
That is assuming it was working and now it isn't.
Good luck
Old May 29, 2019 | 11:13 PM
Billymac's Avatar
Billymac
Cruising
Thank you!!!
Old May 30, 2019 | 01:18 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Gotta know what year!! Automatic a/c, or manual? If it's an early C4, I'm going to guess it's a bad relay. Probably located below your a/c - heater fan motor, but we need to know the year!!
Old May 31, 2019 | 09:29 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
I just had this same problem on my 85. I replaced the blower motor resistor and the problem remained. I then replaced the blower motor relay and the problem was fixed. All fan speed positions work correctly now..
To ac fan switch
