*spring* type hose clamps
Old Oct 7, 2002 | 01:26 PM
tp85's Avatar
tp85
Default *spring* type hose clamps
Anybody know of a supplier for *spring* type hose clamps? I prefer to use them instead of the worm gear clamps.
Old Oct 7, 2002 | 03:35 PM
jsaunde2's Avatar
jsaunde2
Default Re: *spring* type hose clamps (tp85)
I think you're smoking crack if you like those more, but you can probably just ask anyone that has pulled a bunch off of their car. I personally have about 15 strewn about my garage but most of them are mangled from removal.
SOrry I have no info, I just can't believe you prefer them.
Jason
Old Oct 7, 2002 | 04:43 PM
LeadFoot's Avatar
LeadFoot
The spring type clamps are much better to use, you can always be sure the correct tension is on the hose. the dealer is the only place I know to get them.
Old Oct 7, 2002 | 04:57 PM
sunrise.cm's Avatar
sunrise.cm
Default Re: *spring* type hose clamps (LeadFoot)
Absolutely correct. Got mine at the dealer too. You can buy a tool which makes R&R springclamps a breeze. The way kill a hose in a hurry is to use a screw clamp and over tighten it and watch to clamp eat into your hose.
Old Oct 7, 2002 | 05:05 PM
JonM's Avatar
JonM
Check with the guys in the C3 Forum
Old Oct 7, 2002 | 05:56 PM
fullboogie
Default Re: *spring* type hose clamps (JonM)
Whoever invented those hard-to-take-off little bits of evil should be shot. Ever try to get one off that had the little tabs rotated to an inacessible area? :eek:
Old Oct 9, 2002 | 06:01 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: *spring* type hose clamps (sunrise.cm)
They make screw type clamps where the band isn't threaded... The bolt threads into a square nut. Although I can't tell you who makes em off the top of my head. Those spring claps SUCK! Need a small third-world militia force to remove them.
Old Oct 9, 2002 | 11:18 AM
fullboogie
Default Re: *spring* type hose clamps (CentralCoaster)
:lol: :lol: :lol:
Old Oct 9, 2002 | 11:25 AM
Jim D's Avatar
Jim D
Default Re: *spring* type hose clamps (fullboogie)
The band clamps that don't cut into the hose can be ordered from McMaster-Carr.it an industrial supply house , there phone is 908-329-3200 they don't list a website.good luck Jim.
Old Oct 9, 2002 | 11:26 AM
vettmech's Avatar
vettmech
OH BTW....... when we throw those spring clamps around make sure we don't drive over them....... :lol: ever try to remove one even with the proper tool that has already been mangled by someone else?. :lol: :seeya
Old Oct 11, 2002 | 03:28 PM
tp85's Avatar
tp85
Default Re: *spring* type hose clamps (Jim D)
McMaster- Carr has all sorts of clamps. Worm gear clamps that don't chew up the hose, worm gear with springs, and, the type I was looking for, spring hose clamps (PN 7329K11).
http://www.mcmaster.com
To *spring* type hose clamps
