'93 40th Anniversary Vette Engine stops intermittently
I recently bought a '93 40th anniversary Vette....Ruby red. It really looks good on the outside. However, after a few times driving it around, the engine will die when sitting at a stop light....sometimes.
Sometimes, it won't start while engine is warm...(drove to Mom's, visited 2 hours, got in and no start) The battery is 14volts, there is plenty of good sounding cranking going on, just no engine firing up.
The car has 39,800 miles. The fuel pump is new, the alternator is new. The throttle body was cleaned and new gasket. The security system seems ok...(security light extinguishes when key is in ignition)
Mechanic started the car, getting ready to pull up onto the ramp to raise it, but the engine dies...then will crank, but no start. When we wait about 30 mins. the car will start....sometimes.
The other thing it does but is livable, it hard shifts from gear 1 to 2.....shifting is smoother when letting up on the gas peddle between 1 and 2nd gear....gears 3...less hard..and so on.
The engine also died while I was driving it on the highway at 60mph....(rpm was at 0) but then the engine (rpm) came back up again.
Can anyone help solve this mystery?
First Corvette owner,
Jeff
Jeff
https://www.youtube.com/results?sear...+lt1+optispark
I have a 93' and did the same thing, it would just died, when it cool down it would start. It was the opti, it took me 4 hours to fix it , I only have one arm to work with. After the fix it still runs great I all so changed the water pump coupling, I think the coupling was the whole problem it was hitting the Opti
2) To me it sounds more like a fuel delivery issue than an opti spark. Particularly with only 40K on it.
I would sure invest the time to eliminate the possibility of a fuel issue before throwing an opti spark at it. You say that the fuel pump is new. Did you install the new fuel pump or did the previous owner say that he "recently installed" a new fuel pump?
Welcome to the forum. The 93 Ruby is a beautiful car
Depending on where you bought your new fuel pump, even new pumps will fail or be a problem out of the box. The new parts these days are horrible.
Here is my 93 Ruby LT1 6 Speed ZO7:
