On my old engine, the knock sensor is located in a hole in the block just in front of the starter next to the 4th oil pan bolt on that side. On my new engine, there is a block plug. Can I remove that plug and put the sensor there, or is there something special inside the vette block right there that would negate this interchangablility? :cheers:
OK. Maybe it's not the knock sensor. I pulled it off my car and darn near got a coolant shower. If this isn't the know sensor, is it a coolant temp sensor? I thought those were on the heads (one per side). Someone explain this to me please :confused: :smash:
There is a collant sensor in the front of the block under the intake and another between #6 & #8 plugs.
The knock sensor is just in front of the starter near the bottom of the block; it goes into the water jacket.
The '85-'89 Vette has an ESC module just above the right side panel near the blower motor. The knock sensor plugs into this unit, which processes knock information and relays it to the ECM.
Just out of curiosity, how does the ESC module process knock info from coolant?
Think SONAR; liquids can transmit sound waves fairly well. Of course any percussive sound on a solid surface will travel even better thru the alum/iron of the engine to where the knock sensor is.
The knock sensor signals the ECM when knock is detected and the ECM pulls timing to reduce knock tendency; this protects the engine from destructive knock.
However, after warmup the ECM advances timing till the knock sensor registers a ping; if this "test" fails the ECM goes into Limp Home mode with fixed timing and a rich mixture to protect the engine till the knock sensor is fixed.
So,yes the knock sensor is an important part of our EFI engines.
The GM manual specs NOT TO reinstall the knock sensor. Once torqued down, then that's it. I guess it is so sensitive that the untorquing and re-torquing will distort the sensor housing and affect its performance. Good luck!
