How will the LT1 computer work in earlier C4's?
Old Oct 7, 2002 | 11:03 PM
Wilson6t7's Avatar
Wilson6t7
Default How will the LT1 computer work in earlier C4's?
I am thinking about buying a 84 that comes with a 97 LT1 and computer with it. How will the computer work for the speedo/tach/all the oil pressures/temps/and onboard diagnostics?!?!
TIA!
:seeya
Old Oct 7, 2002 | 11:15 PM
MrNuke's Avatar
MrNuke
Default Re: How will the LT1 computer work in earlier C4's? (Micky T)
I dunno about your question, but an '84 with a '97 Fbody LT1 would be an AWESOME sleeper.. :cheers:
Old Oct 7, 2002 | 11:17 PM
GlockLT4's Avatar
GlockLT4
Default Re: How will the LT1 computer work in earlier C4's? (MrNuke)
:yesnod: :yesnod: :yesnod: :yesnod:
Old Oct 8, 2002 | 12:10 AM
Wilson6t7's Avatar
Wilson6t7
Default Re: How will the LT1 computer work in earlier C4's? (Glock'94)
Ya, and I was planning on a LT1 hot cam+headers and maybe a 100 shot of the funny stuff :yesnod:
Oh, and guys, will it throw a bunch of codes too!?
:cheers:
Old Oct 8, 2002 | 12:28 AM
Goody's Avatar
Goody
The 'puter isn't going to know what kind of car it is in or the year. So long as you have all the stuff hooked up the way it is from the factory, there shouldn't be any real problems. Just know that you will need other stuff for it to all work. The PCM talks to the CCM and other modules for info/codes. The PCM controls the tranny shifts and TC lockup functions if A4. It's just not a simple bolt in process. Requires lots of technical expertise. Longtube headers will not fit an A4 C4. Not enough room. M6 requires bullet cats for clearance. Big project....So, Good luck. :seeya
Old Oct 8, 2002 | 03:39 AM
GRX's Avatar
GRX
The 97 computer won't be able to talk with the 84 digidash without some major interface circuitry adapting between both. Are you an Electronic engineer? :blueangel:
Old Oct 8, 2002 | 05:52 PM
Wilson6t7's Avatar
Wilson6t7
Default Re: How will the LT1 computer work in earlier C4's? (GRX)
:eek: How much do you think it would cost to convert!? :eek:
To How will the LT1 computer work in earlier C4's?
