1994 Engine Shakes When Stopped in Drive Code H64
Today when I took the car on a test drive after replacing the o2 sensors, the car ran great, till the end. After about 20 minuets of driving I pulled into my drive and let off the gas to slowly drive in, the car sounded like it wanted to die. The engine was shaking bad and chocking up. When I put it in park though, the car stopped doing this. I put it back in drive and it started shaking and chocking up again. The car seems to only do this in drive. I then checked the codes again and H64 was back. Any ideas about what is causing this? I really want to get the car running again, it just keeps breaking almost every week.
If it's getting physically broken then it's definitely a mechanical issue that you would have to locate and resolve.
Now a bad output signal could be caused by several things like oil contamination inside the exhaust pipe or sealer covering the wire connection where the sensor needs to breathe. Or the wires could be at fault causing shorts or opens.
Good luck.
Good luck.
Any solution yet I have the exact same symptoms
