what is this wire
Old Oct 25, 2017 | 02:27 PM
renhod's Avatar
renhod
Default what is this wire
where does this wire go
Old Oct 25, 2017 | 03:08 PM
Space387's Avatar
Space387
The large braided wire is a ground strap, they are needed for good clean power in your electrical system. The black wire is a shady example of how not to ground something. Treace the small wire back to its origin and see what its too. If it is needed ground it to the end of the ground strap with an O-ring connector and a wire brush.
Old Oct 25, 2017 | 03:27 PM
s carter's Avatar
s carter
Trace the unknown back it may be a Redundant Ground from a General/other Application Antenna.
Old Oct 25, 2017 | 08:47 PM
Space387's Avatar
Space387
That is actually the ground strap for the antenna, definitely move that "extra" ground wire to the chassis. You are probably causing an issue with radio interference like that
Old Oct 26, 2017 | 07:58 PM
cshuman's Avatar
cshuman
The small wire is a floating ground plan for the antenna. It is factory upgrade to improve the reception. There are a couple of these. They are floating and are not suppose to be grounded to the frame that I remember
Old Nov 1, 2017 | 03:27 PM
TravisD's Avatar
TravisD
Just did the power antenna on my '96 and can confirm - there are wires coming from the antenna that just dead-end -- the one in the fender well is attached to a small xmas tree type clip that goes into the frame to hold it in place.
Old Nov 1, 2017 | 04:01 PM
WVZR-1's Avatar
WVZR-1
This is correct and I believe there's actually four. All should be BLK/WHT
From a later FSM:
Name:  Antenna Ground Plane.jpg
To what is this wire
