Help - Headlamp fit adjustment
Old Oct 8, 2002 | 03:13 PM
T1Kilr's Avatar
T1Kilr
Default Help - Headlamp fit adjustment
I would like to improve the fit of the headlamp bucket in the hood opening. Can anyone suggest the best method or the order in which to make adjustments? I have a little bit of a rub along one edge that I want to correct before it gets to wearing too much.
Thanks!
Old Oct 8, 2002 | 03:57 PM
REW89's Avatar
REW89
Default Re: Help - Headlamp fit adjustment (T1Kilr)
I watched Gordon Killibrew do this to the headlamp shell this spring, if it is the same problem. The bucket/shell has a screw on each side (?). If so, stop the headlamp rotation in mid cycle, loosen those screws, and you can adjust the shell a little to allow for not hitting/scrapping the hood as it moves back and forth. It even took Gordon more than a few trys to get the alignemnt just right, so don't give up.
Bob White
Old Oct 8, 2002 | 04:18 PM
Raistlin's Avatar
Raistlin
i just fixed the bushings in the motors. i had to take the whole headlight assembly off the hood. it's real easy, it's only attached in 6 places, 2 nuts on each side and 2 screws on the bottom. when i put the lights back on, i was able to center the lights in the hole. it did take 2 people, one to hold, one to tighten.
guess i should re-aim my lights :lol:
i just realized that now :crazy:
Old Oct 9, 2002 | 12:57 PM
T1Kilr's Avatar
T1Kilr
Thx guys... hadn't thought of doing the mid-flip thing. Will give it a try!
To Help - Headlamp fit adjustment
