temp sensors location in 85 corvette
(edit) the pic shows the location of coolant sensor (blue arrow). the cold start injector thermo-time switch (red arrow) - used only on the 1985-88 TPI engines.
edit: just realized the sensor locations in the pic are reversed. this pic came from a Camaro site, and I can't swear it is correct. the location of the sensors is opposite from my 85 corvette, and my 85's sensor location seem to be in a natural position for the wiring harness.
And in an 85, the aux fan switch OR the override switch for the main fan is on the PASSENGER head, between 6 & 8, and the gauge sender is in the DRIVER head, between 1 & 3. In 86-up, the positions reverse.
(little confused) looking at my FSM, I don't see anything that addresses an "override" switch for a single fan cooling system - ???
