Bar behind the seats
Old Nov 4, 2017 | 08:53 AM
kansas123's Avatar
kansas123
Default Bar behind the seats
A friend of mine has a '95, and behind the seats from floor, then up and over to the other seat, and back down to the floor is a thick bar. Knowing nothing about this year of car, I have to ask if this is a roll bar or what? It severely limits movement of the seat, the seat back specifically, and so the seating is quite uncomfortable. Can this bar be removed or is it welded in? Is this standard equipment for these C4s? Thanks. Far as I know this has base engine etc.
Old Nov 4, 2017 | 09:32 AM
Kevova's Avatar
Kevova
Is bar above or below carpet? Above it might have been added. Under carpet part of frame, not practical to relocate.
Old Nov 4, 2017 | 11:50 AM
c4cruiser's Avatar
c4cruiser
Sounds like its a "Harness Bar". They are used for mounting the shoulder straps from a 5-point harness belt system, typically found in autocross or track cars.
Are there any bolts that can be seen? If so, you should be able to simply unbolt it and remove it from the car. Depending on the construction of the bar, it may be just bolted to the floor.
It may that the best way get to the bar is to remove the seats.
Old Nov 4, 2017 | 06:03 PM
C409's Avatar
C409
..... Have you LOOKED ? ... we here on the forum have that as a disadvantage ... you don't .....
Old Nov 4, 2017 | 06:57 PM
s carter's Avatar
s carter
As mentioned we are at a bit of a Disadvantage a picture would be nice .Does it look something like this.
Old Nov 4, 2017 | 07:15 PM
Kevova's Avatar
Kevova
Damn those are some speakers. It's all about the bass....
Old Nov 5, 2017 | 09:46 PM
kansas123's Avatar
kansas123
No, nothing like that. Just a single bar, floor up the side (not attached at the sides, over to the other side and down. Thanks.
kansas123's Avatar
kansas123
I am very very sorry that I did not look before asking the question, I thought I might get a simple yes or no answer, since I did not know when the next time I would see the car would be.....Just thought I would ask, is all....
Old Nov 6, 2017 | 09:31 AM
TorchTarga94's Avatar
TorchTarga94
Sounds like an RD Cross Brace. If he doesn't want it I will buy it.
Old Nov 6, 2017 | 08:52 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I am very very sorry that I did not look before asking the question, I thought I might get a simple yes or no answer....
There is no visible bar like you describe as standard equipment in any C4.
Old Nov 6, 2017 | 09:38 PM
Bigpoop's Avatar
Bigpoop
Well the thread title really got my attention. But after reading the posts....well. .. I was...wrong place...wrong time. Where is the ice?
Old Nov 6, 2017 | 09:57 PM
s carter's Avatar
s carter
In the end we agree Not a GM thing at least not Normal out the door thing.
Old Nov 7, 2017 | 08:13 AM
kansas123's Avatar
kansas123
Thanks very much! Have a great day.
To Bar behind the seats
