I have a BORLA, and ABSOLUTELY HATE IT! Buying a Corsa as soon as I can. The BORLA resonance drives me out of the car! Corsa only makes one exhaust - zero resonance.
I got SLP on mine, it came on the car when i purchased it so the exact model i can't tell you but i sounds real good. I won't lie it does have some moderate resonance, especially when your going up a hill and the enigine is under load without downshifting, it can become a little annoying. Corsa seems to be the exhaust of choice of most members.
i put a B&B on mine...not as loud as i thought it would be. i like it pretty well, and i think it will only get better with headers and no cats. fits perfectly (even consider that i put an LT4 system on my LT1).
Originally (when i had the 350) I had the SS exhaust 3in twin tip exhuast as seen in Mid-America mag for $299.99. The great incentive with this application was that it truly cleans up the rear of the vette tremendously!!!!! They sounded great but had slight reasonance at 40ish mph. Not too bad. I have since moved on to Flowmasters 40series two chamber and this works better by way of performance and sound with my current set up with the BBC. You can see my website with the 3in SS set up from a side view. Good luck!
