Overdrive switch actuator block spring
Old Nov 10, 2017 | 12:20 AM
AlV's Avatar
AlV
Default Overdrive switch actuator block spring
Hi,
I recently acquired an 88 with the Nash OD. There was toggle switch rigged to the wiring for the OD bypassing the shifter switch.
I spent some time tonight removing the old switch to replace it with a new one and didn't find an actuator spring inside the block assembly. I'm looking for some reference info, pictures or something to help me understand where the spring fits into the actuator block and what it does. The only thing I can find online and on the forum is a warning that says DON'T LOSE the spring LoL But what if it isn't there and I need to figure out a fix.
for the time..
AlV.
Old Nov 10, 2017 | 08:14 AM
WVZR-1's Avatar
WVZR-1
Here's an image of the shifter with #42 being the spring.
GM part# would be 14101389.
If someone had a correct shifter maybe they could ID the spring for you as to # of coils, the length and OD. A generic compression spring from a hardware store could I'd think conceivably work.
Name:  4+3 shifter.jpg
Old Nov 10, 2017 | 10:35 AM
AlV's Avatar
AlV
Attachment 48223883
Perfect! Thanks for the image, this makes sense now. it fits in the hole on the bottom of the block which I presume assists with returning the block and switch to the up/ open position.
If someone has a spring and could share the dimensions I would appreciate it.
all the best.
AlV
Old Nov 10, 2017 | 10:57 AM
WVZR-1's Avatar
WVZR-1
all the best.
AlV
If you've a relationship with a GM dealer maybe take the part# and image to the parts dept and ask for some help regarding dimensions. Not always but often they can help, much depends on their understanding and the interest of the guy/gal on the other end of the conversation at GM.
Old Nov 13, 2017 | 06:32 PM
vtdave577's Avatar
vtdave577
Attachment 48223883
What is #41 and what does the little "t" rod push on? Wish I could find a microfiche or something that shows how it all goes together and what the parts are.......
Old Nov 13, 2017 | 10:21 PM
AlV's Avatar
AlV
Well first off I'd like to proclaim hell yeah I got lucky and found the actuator spring in the drivers power seat transmission housing, in perfect condition!
Vtdave, having just done this I can tell you that number 41 is the actuator block for the over drive switch. The switch pin slides into the actuator block and is held in place by a tiny pin. It (the actuator) also holds the actuator spring (which I've determined helps return the switch to the off or up position). The little tee stem slides down along the outside of the shifter and into the top of the actuator block then screws in to it. The button snaps onto the t section.
I hope that helps.
AlV
To Overdrive switch actuator block spring
