Driveline support beam (c beam) queston
1994 4A. I am going to stary installin my Dana 44 with new 4.11 The FSM calls for urethane sealet between the c beam and diff and c beam and trans tail housing. Is it necessary to use urethane or can another sealer work. Last night I stopped at a couple of auto parts stores and they didn't carry the urethane (I live in a small town). When I changed out my torque converter I just used RTV to reassemble. But I'm having second thoughts since this diff will be taking more of a beating. If you've done this What have you done? Thoughts?
See a local windshield installer and see if they'll sell you a tube of their urethane window-weld sealant. 3M branded stuff is fairly expensive and maybe over-kill. From a mobile installer that doesn't pay for his supplies might be very inexpensive!!
Check maybe also a local auto body supply store or body shop. They'll understand.
Years ago I believe the most mentioned adhesive was "liquid nails" - I believe you need to be primarily concerned with sealing and NOT an adhesive. RTV maybe.
Used 3M Window-Weld previously maybe just because it was handy. Did you buy or fabricate 'beam plates' for the install? I would buy or fabricate if you're not rushed.
Originally Posted by mrodoc
1595988174 The FSM calls for urethane sealet between the c beam and diff and c beam and trans tail housing. Is it necessary to use urethane or can another sealer work.
Vic
It's for anticorrosion effects. Don't need it unless you drive a lot on snowy, salty roads. Had mine off and on many, many times with no sealer. No problems.
C4 of Year Finalist (appearance mods) 2019
But the two beam plates that WVZR-1 is talking about are not a stock item. They are an aftermarket item that add significant stiffness to C-beam where it bolts to the trans and to the diff. Expensive little items to purchase but worth it. A number of folks have made their own.
..... Or buy some grade 8 USS flat washers for the beam bolts and save yourself $200 ... I have never seen a C-beam fail that was not collision related .....
The stock setup worked for me. Open end 18mm wrench to hold the tranny bolt nuts from above. Use 18mm socket with an impact wrench and torque the two bolts to 55 ft/lbs. 21mm open end wrench and socket for the differential bolts. Impact and torque to 60 ft/lbs. Just push the open end wrenches out when done. Never a problem or concern.
Regarding the 'beam plates' - a fellow local here doing a D44 swap purchased 3 C-beams before he got one that didn't have the bores elongated on one end or the other, the 3d actually had some elongation but not near as bad as first 2.
He asked about the 'beam plates' and with his set of circumstances and wanting to do a 'once and done' I mentioned using them might show some merit.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
and as I said I used "Liquid Nails", contractor grade
