1990 32&36 abs codes
Old Nov 22, 2017 | 07:05 AM
max76's Avatar
max76
Default 1990 32&36 abs codes
Hi guys,
I have a old problem, but ill like to fix it.
Sometime the abs service light come on the dash, appear and disappears, during the road trip.
I check the codes and I found 32 & 36.
I check the toothed wheels and its looks good.
The curious things is that a my friend have a 1990 l98 and we found the code 36.
What we can check?
Please, help us...we don't have the tech1a
Old Nov 22, 2017 | 11:55 AM
max76's Avatar
max76
Nobody?
Old Nov 22, 2017 | 01:25 PM
hcbph's Avatar
hcbph
If you don't have a fsm, I'd recommend getting one.
In the mean time, check out this site: http://tech.corvettecentral.com/2011...trouble-codes/
Old Nov 22, 2017 | 03:49 PM
bosshog8's Avatar
bosshog8
CODE 32
RR TOOTHED WHEEL (FREQUENCY ERROR)
CODE 36
LR TOOTHED WHEEL (FREQUENCY ERROR)
The procedure to diagnose is pretty much just look for damaged teeth or a loose mounting. Then replace if you find something wrong. I would suspect the harness since it's both. You need some electrical diagnosis skills if that's the case.
Old Nov 22, 2017 | 05:00 PM
max76's Avatar
max76
Ok guys...thank you!!!
To 1990 32&36 abs codes
