What next?
Old Oct 9, 2002 | 05:55 PM
dtorc4's Avatar
dtorc4
Default What next?
I got the engine installed today. The bellhousing bolts and motor mounts are all torqued down. Now what? Is there anything I should look out for when I reassemble everything? I was thinking of wiring everything up and then putting on the hard parts. Any other ideas? :cheers:
Old Oct 9, 2002 | 06:09 PM
jmr302's Avatar
jmr302
Default Re: What next? (dtorc4)
Last time I did this I started with the starter/headers/batt cables and the rest of the undercar stuff (trans harness, trans cooling lines, exhaust etc). This way none of the drivebelt accessories are in the way during the header install. After all the undercar stuff is done set it back down and install the balancer and the drivebelt accessories. Then you have the intake/distributor/fuel rails. You can install that stuff with the injector harness pushed out of the way.
