tapping sound
Old Nov 29, 2017 | 06:02 PM
in distress's Avatar
in distress
Default tapping sound
[QUOTE=biggiefl;1596071015]"don't know if I can do that with a throttle body."
Try Seafoam in the TBI...she'll smoke like its on
ok thanks I'll give it a try
Old Nov 30, 2017 | 08:18 AM
in distress
Default Tapping sound
Try Seafoam in the TBI...she'll smoke like its on fire
Does Seafoam clean the valves that way??
Old Dec 3, 2017 | 08:41 PM
Space387's Avatar
Space387
This sounds a lot like my LT1 Firebird did when I first got it running. The #8 conrod bearing spun and stacked both sides on the top end of the opening. Ended up pulling the motor and rebuilding it to the tune of just under $1,000. How is your oil pressure reading? failrf bearings usually produce a lower pressure readout
Old Dec 4, 2017 | 09:53 AM
biggiefl's Avatar
biggiefl
Piggy Back a rod bearing is gonna be a lot louder than a tap when the piston is ramming the cyl head.....don't ask how I know.
Old Dec 4, 2017 | 06:51 PM
in distress
Default Tapping Sound
I live in Port St Lucie does any one know where I can have my cylinder heads professionally remanufactured.
Old Dec 5, 2017 | 05:08 PM
in distress
So far new push rods, rockers, and lifters. Could it be worn valve guides?? when oil temp get's above 214 degrees about 15 to 20 minutes the motor is quite
Old Dec 8, 2017 | 07:16 PM
in distress
Originally Posted by cadmaniac
Sounds like a valve train noise from what you describe. I'm still leaning toward the rocker arms....
So far I replaced lifters, pushrods, & rockers. I still have the same tapping sound. But the engine sounds & runs a lot smoother.
Old Dec 16, 2017 | 02:41 PM
in distress
I put 2 wire ties on the cap and my bud and I pulled the ties with pliers.....bitches were in there.
I am going to try those wire ties and also see if I take off the wheel well might make the job a little easer
Old Dec 17, 2017 | 08:12 AM
scrappy76's Avatar
scrappy76
Originally Posted by in distress
This is a 96 C4 LT1 at start up it is very quite, after 15 or 20 sec. a slight tapping appears and get's louder, when it gets louder it sounds like it's metallic. mainly on the drivers side. after the motor get's hot the tapping sound get lower and lower to a point after about 15 or 20 minutes it is barely noticeable. Turn the car off let it sit 10 or 15 minutes, start the motor a slight tap appears, then seems to go away.
Replaced al lifters with Delco push rods are straight appear to be ok. When listening to the motor underneath behind drivers side tire it is extremely louder. Also tapping sound seems to be in rhythm with the of the exhaust. Can any one point me in the right direction.
If the noise is louder underneath the car, and it goes away when engine is warm, I would think a really small exhaust leak.
Old Dec 21, 2017 | 10:58 AM
hcbph's Avatar
hcbph
I don't have a LT1 so take this with a grain of salt. Can you get to the plug wire from the bottom? If so, pull it and start the car and see if it's still making noise. Don't know if that will help or not but worth a shot.
I think I remember reading where someone had noisy injectors, worth a check and see if they're making excessive noise.
