Rotor and Dist change-now problems
Old Oct 9, 2002 | 08:35 PM
aroulette's Avatar
aroulette
Default Rotor and Dist change-now problems
Ok! I swapped out the dist cap and rotor. After swapping I started and digital dask is freeking out, I hear a grinding noise in dash. I shut down immediately. What is this. Can I fix tonight?
Old Oct 9, 2002 | 09:09 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Rotor and Dist change-now problems (aroulette)
When you swap distributor caps, It is easy to get the two single leads, I believe they are brown wire and white wire reversed....I think!
At least I believe that's how my 88 works...but then I could be confusing it with one of my older Z 28's
Anyway, be sure you have the wire leads to the cap in the right place.
Oh yeah, another thing...you probably changed the coil in the cap too!
Did you get the solid metal connector back in correctly?
Just some crazy ideas
Jack
Old Oct 9, 2002 | 09:13 PM
aroulette's Avatar
aroulette
Default Re: Rotor and Dist change-now problems (jackdaroofer)
I put everything back in same way. Please help!
Old Oct 9, 2002 | 09:27 PM
aroulette's Avatar
aroulette
OK guys! I think I got it fixed. I took the coil cap off and retightened. I actually turned the screws about 2-3 times and dash is ok. Thanks
Old Oct 9, 2002 | 10:06 PM
Bill-35thAnvrsy-88's Avatar
Bill-35thAnvrsy-88
Jackdaroofer,
What does your signature mean when you say "700HP with free mods". This really got my curiosity goin!
Thanks!
Old Oct 10, 2002 | 08:45 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: Rotor and Dist change-now problems (Bill-35thAnvrsy-88)
Jackdaroofer,
Thanks!
That's kind of a tongue in cheek, satirical comment about all those who claim that changing a hose or bolting on a ten dollar part will add gobs of horsepower
sorry
:reddevil made me do it!
Jack
Old Oct 10, 2002 | 09:31 PM
Bill-35thAnvrsy-88
Got that! :lol:
To Rotor and Dist change-now problems
