Fuel pump wire from ECM
Old Nov 29, 2017 | 07:03 AM
Ian67's Avatar
Ian67
Default Fuel pump wire from ECM
I hope some one can help me with the fuel pump wiring. I have a 92 LT1 and I'm trying to find the wire that is switched by the ECM to operate the fuel pump.
Old Nov 29, 2017 | 09:03 AM
Kevova's Avatar
Kevova
Grey wire runs from FP1 fuse to pump.
Red wire runs from oil pressure switch and fuel pump relay (30) to FP1 fuse.
Red wire at (87) of relay receives 12v from Fuel Pump fuse.
(86) Dark Green wire at relay comes from ecm D7 to turn on relay.
Black and White wire at relay (85) is ground. Fuel pump relay terminals are 87a 87,30,86,& 85.
Old Nov 29, 2017 | 09:28 AM
Ian67's Avatar
Ian67
Thanks for the explanation on the relay numbers, it really helps. These are the colors at my relay; Black & Orange at 87, Dark Brown & White at 87A, Black & Orange at 86, Black at 85 and 2 red at 30. I'm glad that I understand these relays, other wise that wiring would have got me confused.
Old Nov 29, 2017 | 05:37 PM
playsdixie's Avatar
playsdixie
you sound very knowledgeable....perhaps you can help me with my fuel pump wiring....on my 85 I can apply 12 volts to pin A on the relay to bypass everything...can't get the pump on...bench tested it, it's fine..I can get 12 volts at the fuse from pin A but if I restore the relay, no voltage at the fuse box....pump does not come on in either situation....
Old Nov 30, 2017 | 04:28 AM
Ian67's Avatar
Ian67
I've got to be looking in the wrong place. I can't find a relay with these color wires going to it. Back to the garage and look some more I think.
Old Nov 30, 2017 | 08:27 AM
Ian67's Avatar
Ian67
I found the pump relay. It was hidden above a bunch of wires
To Fuel pump wire from ECM
