bad egr??
Old Oct 10, 2002 | 01:47 AM
want2drivemy85's Avatar
want2drivemy85
Default bad egr??
What problems would a bad egr valve cause at idle and throughout the rpm range? Say, on an 85 vette. I don't really understand what a bad one would do, or under what parameters the thing operates. I know its supposed to divert exhaust back through the intake for emission reasons, but when and why?
Old Oct 10, 2002 | 04:28 AM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
Default Re: bad egr?? (want2drivemy85)
Regardless of what some on this board may claim, don't just "leave it because it doesn't matter". Either fix it or get rid of it completely.
It should be closed at idle. If it's open it could cause anything from a rough idle to a no start if open enough.
It should only be open at part throttle. The computer uses inputs from different sensors like engine temp, manifold air temp (I'd have to check my Helm's for others) to determine when to engage the EGR. Other than a possible "Check Engine" light, I don't think you'll see anything.
At full throttle it should also be closed. If it's open you're allowing hot exhaust air into your intake which will cost you power.
Old Oct 10, 2002 | 04:55 AM
want2drivemy85
Default Re: bad egr?? (Ron78Z&85Vette)
Great! Now, if you are checking it at idle, can you manually check it to see if it is open or closed?
Old Oct 10, 2002 | 03:29 PM
Ron78Z&66Vette
If your fingers are long & skinny enough you may be able to reach up underneath and feel for it.
Or use a small inspection mirror to look at the underside of it. You'll have to get creative to find an angle and location to get the mirror under the plenum for a good view.
Old Oct 10, 2002 | 04:56 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You've got mail on how to test & service your EGR system.
Old Oct 10, 2002 | 06:11 PM
want2drivemy85
Default Re: bad egr?? (65Z01)
Thanks Jim!!!!!! :cheers:
Old Oct 11, 2002 | 02:53 AM
1SLO POK's Avatar
1SLO POK
65Z01,
Why dont u post it so everyone can read. :D
Old Oct 11, 2002 | 04:04 AM
65Z01's Avatar
65Z01
Default Re: bad egr?? (1SLO POK)
OK, I just got it up onto my site; hope you find it useful.
To bad egr??
