1984 cross fire c4
1984 cross fire c4
My 84 c4 cross fire runs and drives perfect however i start it drive around park but if i try to restart it, it won't, it just turns over. I let it cool down starts rigjt up mo problem. I replaced cooling sensor and some others but still no fix. This car has a yon of new parts so i dont know what i missed. Any suggestions
Yes i saw that one and replaced the coil, along will cap,rotor,plugs,wires. Also cooling sensor, radiator,thermostat. And more. This car is perfect except this stupid problem.
maybe a bad starter solionid ?
have you cange the fuel pump relay ?
I cant remember i will have to check my notes. This restomod has bin going on for a year now and i dont drive that often. The tank and pump was installed about 10 months ago and i cant remember if i did the relay or not
If it isn't throwing fuel when this happens check to see if it is priming. You said it has fuel pressure is that when it does it as well or no. If not I would suspect the fuel relay. If it is then perhaps a security issue? According to the FSM Chart A-3 cranks but will not run, you can put a test light across the disconnected injector harness to see if it flashes. If you don't have that further digging is involved. If it does flash the book seems to leave a little gap but I'll let you run those tests first. I can scan in the troubleshooting charts if needed.
Since you didn't say anything about it not running good when it's hot, I don't think it's an ICM problem. The problem is only a hot start, not a running problem?
If your injectors are leaking, the engine may be flooding when you shut off a hot engine. Park the car hot, then remove the air filter housing. Do your injectors dribble? Do you have a nice, even injector spray pattern when the engine is running?
