ground strap
Old Dec 13, 2017 | 05:52 PM
abenton's Avatar
abenton
Default ground strap
1987 model. Found cut ground strap. Pretty sure its the one shown page 8A-201-1 fig. 8 of FSM labeled ground strap. Cant find a corresponding reference to terminal location. Can anyone tell me where it connects to? Appreciate your help.
Old Dec 13, 2017 | 06:38 PM
WVZR-1's Avatar
WVZR-1
Look at 8A-30-2 and you'll see it going from G101 to G104 & the component location will take you to 8A-201-1 & -2. I don't believe you'll have any difficulty sorting it. Frame rail below/in vicinity of battery tray to engine block vicinity of oil filter.
Old Dec 13, 2017 | 10:12 PM
gman35's Avatar
gman35
Default extra grounds
I redid all the grounds on my 1987 soon after I purchased it. I added 3 extra grounds to different locations and my lights,charging and everything seemed to improve..
Old Dec 13, 2017 | 11:37 PM
383vett's Avatar
383vett
My 84 has extra grounds also. Better too many than not enough.
Old Dec 14, 2017 | 01:12 AM
Joe C's Avatar
Joe C
Old Dec 14, 2017 | 01:27 AM
abenton's Avatar
abenton
Got it, thank you again!
Old Dec 14, 2017 | 01:38 AM
abenton's Avatar
abenton
Appreciate reference to FSM. Is there a method to go from 8A-201-1 fig 2B back to 8A-30-2 ? Does ref 12A C1, 2 in figure 2B have meaning?
Old Dec 14, 2017 | 08:37 AM
WVZR-1's Avatar
WVZR-1
Took me awhile to sort that. That's only an image reference for the publisher and GM engineering. Every image in the FSM will have a ref in the lower right corner.
A 'short cut' back to 8A-30-2 I'm not familiar with on all of the various digital FSM offerings.
Old Dec 14, 2017 | 08:02 PM
abenton's Avatar
abenton
Thanks again for the help. Lack of grounding connection may explain random glitches Ive been having. On to adding more grounds and original problems clutch slave and brake master cylinder replacement ..
Old Dec 15, 2017 | 05:37 AM
WVZR-1's Avatar
WVZR-1
The ground most responsible for issues inside the cockpit is G201.
Some year FSM don't have a component image in 8A-201. I believe '87 is one that doesn't so in this post is an image.
https://www.corvetteforum.com/forums...post1595481520
To ground strap
