Rear gear Ratio
Old Dec 15, 2017 | 10:00 AM
Merlin1650's Avatar
Merlin1650
Cruising
Default Rear gear Ratio
Just a quick question to those who own a 1991 automatic L98 the RPO code is calling for a 2.59 rear axle ratio. Upon inspection I noticed I have a Dana 36 with 3.07 ?? No changes were ever made to the car. Just wondered if they switched mid year and put in the 3.07’s. From the factory. It’s a coupe
Old Dec 15, 2017 | 11:41 AM
STL94LT1's Avatar
STL94LT1
If the RPO code says 2.59 gears, that's what was installed at the factory. Each SPID label is specific to the car.
Old Dec 15, 2017 | 12:19 PM
Merlin1650's Avatar
Merlin1650
Cruising
Ok just went through all records and according to original owner no work was ever performed to the rear end. Or a diff fluid change, who knows, but they are 3.07. Thanks for the reply
Old Dec 15, 2017 | 12:30 PM
WVZR-1's Avatar
WVZR-1
You did a wheel rotate and confirmed with pinion rotation? OR .....
Some 'D36 will have 3 - 4 lines of information on the bottom of the housing. Some/most D36 don't seem to have that!
Does the SPID VIN match the car?
Old Dec 15, 2017 | 01:01 PM
Merlin1650's Avatar
Merlin1650
Cruising
Measured by counting the wheel rotation vs driveshaft and at 70 mph it’s rite at 2000 rpm
Old Dec 15, 2017 | 01:05 PM
Merlin1650's Avatar
Merlin1650
Cruising
And if it had 2.59 it would have been around 83. Big difference
Auto trans car with 4th at .70% over
Old Dec 15, 2017 | 01:13 PM
WVZR-1's Avatar
WVZR-1
You can't trust the tach and the speedo but assuming accurate yep - I'll assume you can count!! LOL
Old Dec 15, 2017 | 02:04 PM
Merlin1650's Avatar
Merlin1650
Cruising
Been wrenching on these things for years Big block cars that is along with a boat shop for over 30 years , Used my formula to test and backed it up with an on board radar gun and a snap on 2500 scanner hooked up to the test port. Someone told me there was a 3.07 performance axle option but the glove box says otherwise. Just curious if anyone out here had an occurrence like mine. Thanks for the reply’s 👍👍
Old Dec 15, 2017 | 05:24 PM
383vett's Avatar
383vett
I ordered my 84 new a zillion years ago. I wanted the 4+3 and ordered the optional performance axle. Standard was 3.07, mine was a 3.31. The 84s were the one year when all the rears were Dana 36s.
Old Dec 15, 2017 | 07:29 PM
Merlin1650's Avatar
Merlin1650
Cruising
What’s the most power the 36 will handle on street radials ?
Old Dec 15, 2017 | 08:18 PM
383vett's Avatar
383vett
What’s the most power the 36 will handle on street radials ? [/left]
An auto will be a lot easier on the rear than a manual. If on the street, a 36 will do ok. At the strip, if 60's hang around 1.50's, eventually it will break.
Old Dec 15, 2017 | 08:22 PM
Merlin1650's Avatar
Merlin1650
Cruising
Gotcha was gonna build a 430 23deg 11.1 super ram type and was thinking a 44 would be necessary looking for 600 in hp 550 tq. Thanks again
Old Dec 15, 2017 | 09:39 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Zip Corvette sells a modified batwing that has blocks welded to it internally ala the Dana 44 batwing. The blocks support the bearing caps. The top of the caps do need machined to achieve the proper fit. It is considerable cheaper than a 44 and does strengthen up the 36 as far as spring the bearing caps and causing a blowup that way. It will not prevent tooth shear though from a real good hookup and the smaller amount of metal of a D36 gear set lets go.
Old Dec 15, 2017 | 09:42 PM
Merlin1650's Avatar
Merlin1650
Cruising
Sounds like you’ve been there. Thanks for the info. Much appreciated Tom
Old Dec 16, 2017 | 01:07 AM
383vett's Avatar
383vett
I really wouldn't put too much money into strengthening a Dana 36. I blew my 44 a number of times before I went with a straight axle. Others on here have had better luck. I do bracket race often and average about 150 runs per year.
To Rear gear Ratio
