Opinions On This Product
NewCenturion (12-16-2017)
I took a cutoff tool and removed the coolant passage on my 87. Had to for clearance on my miniram. If you just want the TB to not be heated just use a bypass hose.
I've seen several people post about corroded water passages in the throttle body. They were doing a bypass but the lower housing was so bad it couldn't be reused. Since that part is NLA, I could see a use for this in those situations.
