Exhaust Drone!
I had that same style on my C6 too, when I had the GHL system on it. Poo and drone.
Now that Trans Am in the vid above...oval housing, straight through, perforated tube, glass packed...that thing sounds good. I had that same muff on my own TA and no drone. But look at the number of bends in the 3rd gen system! Yikes.
I can't prove anything here...but consider this:
In my C6 days, I tried all kinds of "cat back" exhausts on the thing and none of them really made any diff in the sound (or the drone). What I didn't change, was the configuration of the piping -it was always made up of mostly straight sections w/a few bends.
Now with the Kart, the diff in the Kart exhaust now and earlier is pretty minimal; stock Y to a 2.75" round, straight thru, perforated tube, glass pack style muff. Poo.
Now it's a bendy Y into two, 2.25", round, straight thru, perforated tube, glass pack style muffs, then more bends to the side pipe tips. Music.
What changed? I added bends and separated the sides.
That's why straight pipes and/or cylindrical components sound better. There's still a straight-line transmission of the lowest bass frequencies....and the highest ones. You get the rumble AND the definition of sound.
As for "H" pipes or "Y" pipes, merging the pulses SMOOTHS what you hear. The rhythm is doubled from each pipe making it more like a constant tone vs pulsing. In everything but an idle, tone is mostly what you hear. Also, H/Y pipes can increase the volume (mass) of the system. That changes pipes...and possibly drone. In some older cars, they even added weights to the pipes to dampen the pipes themselves. In the past, I considered trying this to see what happens. Fortunately, that box muffler rusted and I did what I (now) tell others. Try a system with the minimum of components before adding mufflers. If you want sound dampening, start with converters. They help your nose and perform similarly to cylindrical mufflers. They attenuate "boom". If still unhappy, add resonators and/or cylindrical mufflers until you are happy. The exception would be for the person who really likes the Corsa sound and has the money to spend on it. Personally, I think straight-through mufflers sound better.
I got the Borla because I wanted a higher flow and 304 or 409SS for durability because I might drive it in the winter and Wisconsin has salt for roads when the snow falls. It also has to support 420 RWHP, give or take and not restrict the flow to the point it hurts the engine. I could care less about the sound so the quieter it is, the better for the wife and me.
Don't forget BOTH L98s and LTx engine start with 90-deg bends as the down-firing stock manifolds reroute to the rear of the car. Plus, they wind around the transmission, over the rear axle, and at an angle out the back. I think there are lots of bends.
My initial setup looked like this. Headers fired into a dual-inlet/single outlet muffler that was connected to the SideEffects system. Drone was bad in 6th on the highway...which is to say in lower rpms. That was also the case when my stock engine was routed through a main cat and output via targas (mounted in a traditional location).
It's possible we are both right...from the standpoint that a "bendy" system OR cylindrical mufflers end up attenuating mid-bass frequencies....which contribute most to "boomy" tones.
I might be inclined to bypass the Borlas and consider installing cylindrical resonators in the belly. I've also heard the Magnaflow x-muffler with ONLY LT4 cats and straight pipes. I like that quite a bit too. (I haven't heard that over time after the internal batting has had a chance to break down though...) Resonators/glass packs have the added benefit of being cheap too...so it's not an expensive test. I'd probably try traditional resonators in the longest (12-18") you can find.
I'm sure it also matters whether you're running an automatic/manual and (at what) rpms bother you. I think the drone I experienced was lower pitched that most due to the longer run of the SideEffects. What I forgot to mention (in my post above), is that "boxy" SpinTech muffler may have ADDED drone by allowing frequencies to bounce in a non-batted box. Sound is SUPPOSED to "spin" through internal channels in those mufflers -- which you wouldn't expect to collide with other waves. But, I haven't seen one cut apart...to know what the internal baffles LOOK like. The idea is what you hope for -- to get muffling w/o losing power. There's all kinds of "gimmicky" mufflers TRYING to do the same thing. Another company makes a spiral cylindrical muffler that's supposed to do the same thing.
What I've never gotten out of Vizzard's articles is why particular shapes are better than others in creating/eliminating "restriction". For example, I seem to remember his article saying tapered cylinders were worse than some chambered mufflers. I'm not sure I get that...or if there's some "vested interest" in a particular muffler company requiring him to split hairs on the subject? That said, I can see where expandion...followed by contraction induces non-linear flow that's more turbulent than straight pipe. I'm especially confused how one can add a "terminator box" without inducing the crap sound I feel an "open shape" would cause? Maybe an "H" pipe just beyond headers is the best way to accomplish that -- if it can be made to fit under our cars!
Finally, please make sure unwanted sounds aren't the result of pipe "hum" vs poorly tuned exhaust. I see the entire exhaust system similar to a tuning fork. And, it's being vibrated by the escaping exhaust. That means you could also try a quick experiment of clamping weight to the exhaust pipes...just to be sure system resonance isn't part of the problem. BTW...Adding weight should lower any tones related to the pipes themselves. Weight adds mass which slows vibration.
Oh yeah...If you try resonators (or even a Magnaflow x-muffler) in the belly and aren't quite happy, remember you can add MORE resonators down the line. In my OTHER vehicle, I have two sets (end-to-end) in it's exhaust system). Actually, one, then a bend, then the other.
Have you tried it with JUST the cats and no muffler? (If so, I'm curious if it was louder but with less drone than you have now?)
Keep the dual mufflers, Borla Corsa Flo-maters, whatever.
Make sure the exhaust tips are at least and inch beyond the body work as viewed from straight down the rear bumper.
And turn the F**King radio up! Its a Corvette! Not your mamas buick for cripes sake.
FWIW, a new member has a supercharged 750hp C4 with this exhaust on it. I wonder if it's 1000hp without!
Oh yeah....Concede that I have more bends yet?!?! LOL
But I think mine has more bends; where it goes from one direction to another -even if the angularity of change is slight for many of the bends, I believe it matters that it's a "bend", and it changes the exhausts and audio's direction.
Assuming you're feeding TPIS/Random cats into a stock Y-pipe center section, I'd want to change that. More directly, it sounds like you are dumping dual 3" header collectors/cats into a single 3" mid-section. Not the best solution IMO. You've only got a 7cu/in cross-section for the middle with over 10cu/in before and after the split. Besides the center bottleneck, you're doing the opposite of what's recommended. If anything, narrow exhaust down the line...to keep it moving.
I think you have two options: Increase the center "Y" to 4" by converting it to a 4" diesel/race muffler (like this) or swap to a 3" Magnaflow X-muffler (like this). Back pressure will drop dramatically and you'll be ADDING sound abatement. I think both will contribute to improving your complaint. I should also add that the x-muffler might to the most if this theory of bends has merit. (It would add two extra bends.)
Your profile says TPIS long tubes which have 3" collectors. That means you can feed directly into the x-muffler w/o reduction/expansion. A muffler shop could add reducers on the back-end to transition down to your rear 2.5" catback. If you weren't "OK" with the quietest possible sound, I'd suggest dropping the Borlas to see what it sounds like w/o them (and with the Magnaflow x-muffler). In fact, if you buy one, ask the shop to drop it off the rack before they connect your catback. Drive it around the block to see where you'd be. You might be surprised.
I don't know anything about the internal construction of Borla/Corsa mufflers but the cases look smaller than other "performance/sport" mufflers. If either/both are filled with batting, either SHOULD be much better...though [clearly] Corsa gets better reviews. Less batting and/or different chambering could explain why Borlas aren't as well-liked. As for my point about avoiding oval/box mufflers (while recommending the Magnaflow x-muffler, consider that it's filled with batting AND it joins both banks. It's not a typical muffler. Plus, I've heard/driven one on an LT4 with muffler eliminators and thought it was stellar.
https://www.corvetteforum.com/forums...xperience.html
)We've seen/read about the single/double outlet issue for years...including the factory mufflers. Makes me wonder if it's by lowering output/performance or something to do with the way side-by-side sound waves "merge"? I'll have to dig up my PC speakers and see what the difference is really like. (On PC speakers, there's barely a difference)
Mufflers with oval cases (e.g. the stock mufflers) have the least drone.
Mufflers with flat cases (Flowmasters, Hooker, etc.) have the most drone.
I believe it is because the flat cases will resonate/reverberate like a bass drumhead. Oval cases cannot reverberate. All the reports on this forum seem to support this theory.
Smaller bass cabinets tune to a higher frequency...which means the drone would rise in rpms. If it's high enough (e.g., above "bass frequency"), that's when people tend to call it gone -- like Corsas.
When plugging outlets (as described further above), I have to believe it's like removing 2 of 4 speakers in a room. In audio, halving the number of speakers tends to half the volume. By making the second outlet a small hole, the resonant frequent of that outlet rises significantly.....making it more like a mid-range speaker.
Smaller-body mufflers lean toward the same outcome. I think that's why I like cylindrical shaped components better, the chamber part of their construction is a much smaller portion of the unit -- which means they can't let sound bounce around and cause booming. Plus, they will let SOME straight-line bass frequency through so they sound beefier than chambered/box mufflers.
The (flat) rectangular tubing has a cross-section equivalent between 2.5 and 2.75" round pipe. As such, I allowed for the possibility that the dynos (provided in sales brochures) were reasonable in showing an improvement over stock L98 piping...and even a small bit over LTx systems with stock mufflers.
Since most people would consider performance engine fed into headers and an LTx exhaust "reasonable", that's why I decided to keep them after conversion to a 383. FWIW, they were so hard to find back in 2005, it took constant looking until I finally found a good set in 2007.
A picture of them mounted is in a recent "Let's talk spoilers" thread....if anyone is curious about their appearance. Plus, there's finally been a set/two for sale in the past year. Before that, I never saw them anywhere...that lasted 2 seconds. Kinda makes them hard to turn-loose!
If I did convert to a straight-forward setup (like your Kart), I'd only be able to sell the pipes...w/o the side covers. It's still possible though my target buyer would probably been a humid climate where the pipes have rusted out. (Actually, I met a guy locally who had that very problem. Too bad I lost his contact info!) I think it had to do with the fact, he ran exhaust to the back (after removing the side effects) but left the side covers on because they "looked cool". Really? LOL
I might still have a pic on my phone somewhere!
After that, I got over feeling bad about installing a wing on my vette!
Actually, the initial coupler has a nice venturi-style design to it. And, the sweeping bends -- going into the side "rails" -- aren't THAT small of a radius. So, the manufacturer did do what they could to address all the challenges of bringing sidepipes into the 21st century -- while maintaining the ability to please the EPA.
I still think it will be interesting to drop/drive it one of these days....
