northstar reluctor wheel initial setup
Old Jan 8, 2018 | 09:49 AM
87coupe383's Avatar
87coupe383
3rd Gear
Default northstar reluctor wheel initial setup
I've done a ton of research on the Northstar ignition system as used on the SBC. I've read the european patent on the NS ignition a hundred times and I've also built a bench system with reluctor wheel driven by an A/C motor that works, but I still don't understand how to setup the reluctor wheel as it aligns with TDC and the 2 crank position sensors. I also don't understand what gets changed in the ECM(in my case it's the 1227165) when converting from an 87 HEI distributor to the northstar Distributorless system. Can someone explain?
Old Jan 8, 2018 | 11:46 AM
Bwbob's Avatar
Bwbob
this thread may be your best source of info. Good luck
http://www.thirdgen.org/forums/diy-p...way-dizzy.html
Old Jan 8, 2018 | 03:56 PM
Kevova's Avatar
Kevova
Northstar crank sensors read reluctor at different angles. There is one in the upper crankcase and one in the lower. It also uses a cam sensor to locate #1. Northstar also uses sfi. The early engine uses waste spark vs single point ignition. The 2 crank sensors allow for quicker starts. Waste spark is simpler to set up be cause it uses 1 coil for 2 cylinders. One cylinder is on overlap when the other is on ignition. It takes less voltage to jump gap of plug on overlap than one on compression. Coils can build ridiculous voltage depending on system voltage. So coil builds 80kv overlap cylinder uses 5kv to jump plug the remaining 75kv goes to cylinder on ignition. Its a matter of creating a signal or buffer ecm and icm can process. The LTCC module would be a buffer. Buick v6 used both MPFI and waste spark. Crank sensor used an air gap sensor and a balancer with 3 windows one at each crankthrow and one for number 1/4. Since it's mpfi all injectors pulse together. The 1/4 coil is energetized for ignition when single window passes through. Since cylinders are 180 apart in firing order engines starts regardless of whether number 1 or 4 is actually is on compression.
Old Jan 9, 2018 | 10:21 AM
87coupe383's Avatar
87coupe383
3rd Gear
OK, that's a scoop of info but what I am looking for is where to attach my reluctor wheel in the possible 360 degrees that the front end of the crankshaft allows me. The northstar wheel has 24 notches separated by 15 degrees and 8 more that are placed at different locale. The 24 are numbered 1 through 24(how about that). Perhaps the person that answers my question can do so using these numbers along with TDC for #1. Then once the reluctor is placed, where exactly do the 2 crank sensors get nailed? And yes, I know they are separated by 27 degrees. As I stated before, I read the european patent app 100 times or more. Then most important is what happens to the code in the 1227165 ECM that I'm using. I've read the "do away with dizzy" thread many times but still don't understand it as I would like to. The thread I'm referring to talks about max advance, max retard, and Krefangle?, and 70 degrees is used alot. I really would like to understand this part much better. Thanks in advance.
Old Jan 9, 2018 | 11:28 AM
Kevova's Avatar
Kevova
I doubt your ECM will process DIS. I think you will need newer generation (P6). The crank trigger will have to be a balancer. You could also look at L31 fuel management for ideas. Torque head uses external air gap sensor set for idea. It depends on your goals, it maybe better to go the LS route. Good luck.
To northstar reluctor wheel initial setup
