Folks with headers, I need your advice please...
Old Oct 12, 2002 | 04:21 AM
dtorc4's Avatar
dtorc4
Default Folks with headers, I need your advice please...
I was about to install my headers tonight (SLP LT-1 Shorties). The bolt flanges on these headers are flat, except for 3 that have the raised "tube" like the stock manifolds have. I have to mount one particular header on the pass side so that I can put a stud in it to use to support the dipstick.
My question is do you guys still use the rear braces on the A/C and the alternator? The way they are setup, I can't mount the braces to the header bolts like stock unless I get some studs "made".
If I leave those back braces off, will those components flex under high RPM? Or is this just some GM quality control :bs ? Thanks for the help guys. :cheers:
Old Oct 12, 2002 | 05:31 AM
Zix's Avatar
Zix
Default Re: Folks with headers, I need your advice please... (dtorc4)
I have TPIS long tubes and was able to get all the AC/Alternator brackets back in place with some VERY minor grinding to one end of the brackets. You should still be able to use them with your shorties as well.
Old Oct 12, 2002 | 07:16 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
In the junk pile :yesnod:
Old Oct 12, 2002 | 11:00 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Folks with headers, I need your advice please... (mackeyred96)
dtorc4 just wondering why would you take off the stock header and replace them with shortys i really would be surprised if you gain any power from them just my thoughts :cheers:
Old Oct 12, 2002 | 11:10 AM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: Folks with headers, I need your advice please... (CORKVETTE1)
yeah why didnt you run full length headers? :confused:
Old Oct 12, 2002 | 11:30 AM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
I kept them. Just had to modify the ends a little. I used Stage8 bolts of various lengths in place of the original studs.
Old Oct 12, 2002 | 12:04 PM
ericcer's Avatar
ericcer
Default Re: Folks with headers, I need your advice please... (khornet)
I got 2 of the 3 support on my Hooker LT. If you don't put those on, you may have vibration with the A/C on.
Old Oct 12, 2002 | 03:37 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: Folks with headers, I need your advice please... (ericcer)
I had the alternator crack because i ran it without the brace. The stock one would not fit, no matter what so I bought a piece of aluminum pipe, flattened the ends, drilled holes, and made my own. I ground the edges round, and it fits and works fine. I will polish it one of these days too.
Make sure to put some kind of brace back there. My AC on the 91 mounts only on top. No problems there.
Old Oct 12, 2002 | 11:08 PM
dtorc4's Avatar
dtorc4
Well, I got a really good deal on brand new AFR 190s, but they are straight plug design, which negates the use of any premade longtubes. Heck, I can barely get the plug wires on there with the shorties. And I certainly don't have the $$$ to get custom made headers. I got the shorties just to have a little less restriction and to be able to get rid of all the AIR/EGR crap. I will be running a true dual exhaust, and I think this will help out a lot more with the restiction, but, I know, not as much as long tubes will. Oh well. :cheers:
Old Oct 13, 2002 | 06:35 AM
388 SOLid RoLLeR's Avatar
388 SOLid RoLLeR
ive got full length headers (callaway) i chang emy plugs at the track sometimes. about 10-15 minute job. although i do have a ritual for each plug > im so used to it. Anyhow.... bosch +4s giv eme a slight rough ride. dont like them
To Folks with headers, I need your advice please...
